southbend clutch time!!!!
Old 11-04-2005 | 04:50 AM
napa 600's Avatar
the con fe is here! could'nt get a appointment for install until dec 12 ohh well. any last words of advice?
Old 11-04-2005 | 09:47 AM
BADBOWTIE's Avatar
Yeah trade that FE for a dual disk while you still can. I have a FE in my truck and my buddy who is running the same setup got the dual disk and his is so much smoother to drive. Otherwise congrats on the awesome sounding truck.
Jason
Old 11-04-2005 | 12:03 PM
CTD_Neil's Avatar
Dual-Disk is smoother than an FE? Wow.
So Jake your going to throw it on the dyno while your there right? What are you hoping for powerwise?
Old 11-04-2005 | 12:07 PM
napa 600's Avatar
Jason
is it that bad man? just to grabby or what? i don't tow anything but a couple of quads rarely. school me on the differances. thanks bad.
Old 11-04-2005 | 12:11 PM
napa 600's Avatar
with the stocker turbo i don't know. i think there was someone on here that had the same setup and the stocker right around 450 or so? we'll see!! egts through the roof!
Old 11-04-2005 | 12:29 PM
PourinDiesel's Avatar
The FE will start to slip in the 500-550hp area with hard use.
I would advise going with a dual disk before you get that installed.
Old 11-04-2005 | 04:26 PM
triplenickel's Avatar
How much will an OFE hold?
Old 11-04-2005 | 04:48 PM
BigBlue's Avatar
About 450hp. My roommate has the OFE and it's holding 401 very well. Very smooth clutch. Except lately it's been starting out kinda rough. Don't know why though.
Old 11-04-2005 | 05:33 PM
JCLeary's Avatar
Perhaps 'cause it isn't holding and the clutch is now glazed?
Old 11-04-2005 | 11:11 PM
BADBOWTIE's Avatar
the FE has almost no "slipability" at take off it is either in or out. If you try and slip it your truck will bounce around like a beginner learning to drive a 4 cyl honda stick. If I could have driven both before choosing I would have the dual disk. My FE is holding about 500 hp. It is very hard to back up with any kind of trl except in 4 lo. Just mt 2 cents.
Jason
Old 11-04-2005 | 11:36 PM
napa 600's Avatar
hey bad, have you dyno'd that 500 hp? just wondering because sbc says the fe will hold 550 hp-1100 tq right? is yours slipping or holding it well? i've heard great things about this clutch until it seems; the time to install is here. now all i get is that you should get a dd. interesting huh? any info greatly appriciated
Old 11-05-2005 | 12:03 AM
drew03's Avatar
do you think southbend is the way to go? What about longevity?
Old 11-05-2005 | 10:04 AM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
What is the stock clutch rated for???? Just curious!! Also is this a do it yourself type project???
Old 11-05-2005 | 10:24 AM
Nascarcamper's Avatar
I did my SBC swap, was not a bad deal, just make sure you have a trans jack, that 6spd is one heavy piece. The only jerking I get is trying to back up the 5th, it weights in about 14k loaded. This MU 1947 Con. OFE is holding all the power I have thrown at it without blinking an eye. Stock clucth was slipping at 3/3 on the TST with the Edge at 3 and no trailer, don't know HP rating, have never dyno'd it yet, would love to but nothing seems to be close to my area in Michigan, thinking about the Southern Indiana Chapter meet when they decide a date and location.
Old 11-05-2005 | 11:49 AM
BigBlue's Avatar
I don't think that's it. It's only jerky on the start. Other than that it's rock solid and smooth as silk. It definately doesn't slip. He can do a 2000 rpm launch on 35's and it doesn't even slip. Just hooks, boils the tires, and goes.
