Snow Performance Stage 3 MPG-MAX
#31
Administrator/Jarhead
I had once looked for 'heet', it's a gas line dryer, and it says to use that as a subsitute for the snow fluid that snow sells, but it said methal alochol, and not methanol, so I didn't use it.
I dilute my WW fluid to 50/50... am I stupid? Should I run it straight?
#33
DTR 1st Sergeant
If you are using WW fluid, you need to know what dilution ratio it already is. If it is already a 50/50 mix (like the snow boost juice) then you can run it straight if you want, or dilute further to your liking... which depends on your goal. If you want more cooling... use more water, (or 100% water); if you want more power, use more meth... don't go over the 50/50 mix though
#37
I think some of the WW fluids also has detergents and aromatic chemicals in them but I don't know if it would be a problem........
BTW, I have an Edge Juice. Do you think I can tap into the wires from the pyrometer that the Juice uses? Or do I have to drill and tap another pyro? Would I get a false pyro reading with the two units using the same probe wires?
#38
DTR 1st Sergeant
Also, any WW that is using detergents is very bad JUJU.. don't do it... unless you like foam entering into your cylinders... hmm.. might just clean out the carbon though
#39
#40
#41
DTR 1st Sergeant
After a few weeks and the learning curve for it is now over, I like it. It does what it says, however, I don't think the fuel savings (I saw about ~2 increase when just cruising nicely) outweighs the cost of the meth. I had to run at 50/50 to see that. But I can't run at 50/50 when getting into it... then too much stuff and egts are not coming down. I have to run 100% water for real egt reduction. I will tell you I don't know how other guys with some power ran with just a 2 quart bottle... while I can't give any real estimates on "how much" I used and relate it to any way that makes sense-- I will tell you there is a good reason for the 7 gallon jug... I can go through that surprisingly fast when a heavy foot is employed. Their ads say you can get about 500-600 miles when just cruising... I suppose so... maybe.
On the whole I think it is a good investment for those that tow heavy or have big stix to cool.
The system is a little complicated to get installed, but once done it works very well with no problems.
#42
soulezoo:
Glad to hear you like your new Snow System. As you know, I once had an early Snow Water System on my 1996 Dodge CTD.
Boy, I clicked on that link to their site and MAN, that system is pricey! That is almost as much as I paid for my Scheid Water Injection System. I wanted to "back-up" what you said, that being, that I have always gotten the BEST EGT REDUCTION by using straight 100% distilled water in ALL the water systems I have had.
John_P
1992gen1_fan
01-25-2012 12:13 AM
Red3quarter
12-12-2009 11:12 PM
Mega Bass
15
04-20-2007 08:13 PM
masonic-dodge
03-22-2006 04:56 PM
