Sneak peak at the prototype.
Top's Younger Twin
It houses two aFe pro guard Mega Cannon filters or one can change that to other preferred filters as well.
This will be a 'raw' kit which will include the filter coupler for the AFE filters, fiberglas top and aluminum bottom as well as clamps, sensor coupler and smooth bore hose. Mounting brackets will be provided as well. You must remove the plastic valve cover. Painting and final fitment is left for the end user
It can be supplied with 4 inch or 5 inch hose for different turbo applications.
I am still working out a few finer details for fitment and pricing.
I set out to do this for my twins. I am actually surprised how many folks are giving the thumbs up.
This truly is a mental air intake for the folks that want HUGE AIR.
And it ReALLy does sHAkE along with the torque of the diesel.
How does that intake stand up to rain? The newer trucks are probably different, but I know on my 98 sometimes if the speed and rain is just right, I'll get a backwards flow towards the front of the hood.
Now that I've said that, GIMMEE GIMMEE
By the way, I showed pics of your truck to the wife. She said I shouldn't covet thy neighbors truck.
Ed
Ed
Top's Younger Twin
I am heading out of town tomorrow morning to do a photo shoot with Four Wheeler on the Scotty Shaker as well as Road Armor.
Light Force too.
All the pix seen here are of the very first prototype.
Other then a few small tweaks to fitment and final production, this is what will be.
Heres a pic of the steel proto belly pan and the 'raw' fiberglass top.
Light Force too.
Top's Younger Twin
Ed
Ed
I am sure there will be some pros and cons. Hopefully the pros of massive amounts of air and an option for 3rd genners with twins will out weight the cons. I will post my findings as I get them.
Scotty
Looks great Scotty. Something to maybe consider for a looks standpoint, is have the fiberglass piece connect to the hood and blend in a little more. That way, when you open the hood, that piece goes with it and you can check your filters everytime you open your hood and it would kind of blend in a little better. You understand what I'm saying? I'm not trying to put your product down. Just giving some feedback on it.
I disagree! Shaker scoops are so coool - when you rev the motor the whole scoop moves, on a stick truck it would be more distracting than the boost gauge. And just thinking about the way it would torque around on shutdown gives me goosebumps! OK Scotty, now you have to make one for 1st gens that takes a BHAF.
Top's Younger Twin
Blue I comprende but its a shaker and at start up its even more shakey then shutdown.
One thing I have to address is the shaker needs another 1/8" of room on the passenger side to it does not tap the hood.
After this trip I will have all the bugs worked out and will determine the pricing and final design.
Even with just the old 6 level EZ on there I am 150 cooler then a stock box. 100f cooler then the RA3 and 75 cooler then the RA3 and the TAG.
One note...never had any black smoke until I put this on.
I think perhaps the amount of air is telling the sensor its running lean and dumping more fuel til it catches up.
I will be monitoring all of this very closely.
I need a nap.
I need a nap.
Top's Younger Twin
Thanks guys. I am getting two definate responses with this hood.
I either get the perplexed ICK look and a qestion like what the heck did I do to my truck.
Or more often then that I am getting the response of..."WOW that thing is killer or awesome or ... well you get the picture.
So now I tell folks...watch SHAKEY and start it up.
I think I can get a small MPeg off my digital camera...I'll try it later on.
This thing SUCKS...better then the Scotty II better then the Ram Air III.
Time to go to Montana.
Originally posted by Scotty
Thanks guys. I am getting todefinate responses with this hood.
I either get the perplexed ICK look and a quation like the the heck did I do to my truck.
CAn I make a suggestion I always thought it would be real cool to have like a ram head on the hood with those big fiters in it also have the NoS discharge threw the nostrels now that would be bad !!!!!
Edited by Admin Please go review the site rules as to proper posting etiquette
