smoke and lift
i think smarty has pressure now.......with a 6 spd, id go with smarty........imho i factory clutch like a smarty better than the 48re does
so 35's were a bad idea ? i told the guy i wanted 37's but he said they wouldn't work . i did some research i always heard they would work but he said i should go with 35's . should i call him and tell him i want 37's ?
Yes call him up and get what you want. The 37's will fit under a 6" lift without any issues at all.
Look at the blue truck in my sig, it's running a 6" lift w/ 37's Toyo's. No rubbing, clearance issues, ect. IMHO 35's will look ugly under a 6" lift, way to much wheel well gap.
if you got the money for em, i would......xlr8r fit 37's with no lift!!!! i know the guy i got this lift from fit 37's on his but it was a dually with skinnier tires.......if you got the right backspacing on the wheels it should work......if not 36's will
ok , i have an 06 ctd with edge juced w/attitude , straight pipe . how much smoke are you guys getting out of yours ? mine smokes a little bit but only on stage 4 . how can i get it to smoke more ? oh and i just ordered my bds 6'' lift and 35'' pro comp mud terrain tires the total was $2200 . do you guys think that is a good deal ,thats the cheapest i have found them . thanks .
"You DONT really want smoke. not if your going for full power. lil bit but not black out.
Today 05:57 PM"
Incorrect. If you want power -and- need to spool a larger turbo(s) you will NEED fuel. This will absolutely make black smoke until things get going. If you have the air, it will clean pretty good. In the diesel, you need the fuel FIRST as it is fuel that makes power/boost and boost that requires fuel. It's not a linear graph. Perhaps this could be stated better??
Chris
Ditch the juice and get the smarty... I haven't run a juice but the smarty is so fricking unreal... I had the BD Crazy larry on my 05 with a 6" lift and 37's and I could black out half a small town!!!
Here is a pic of my 05
Shane
Chris
Chris
Very true!!!
Yes, you will be so much happier with 37's.. And unruly is running 40's on a stock rim with a 6" lift!!
Shane
Shane
Here is one without the shell..
Big red.. No I sold it... My trucks are all work well and some play!!! But if you think about it I was running 33's before the lift then I put 6" of lift and 37"s well with 4" difference in tires and another 6" of lift it was heck to get into 10-15 times a day and with bad knees it hurt!! Plus I have a daughter and getting her in the back and buckled up was a nightmare.... Did look darned good though!!!!! I got a ton of compliments on it..
Shane
Shane
