Smarty won't connect - Edge CTS doesn't know it's a Dodge
So I have a Smarty s06 PoD (for 2003-2007 trucks) that won't connect to the truck, the truck is an early 04 305/555
When I try to connect the smarty to the truck it continuously asks me to turn the ignition off and press > then it asks me to turn the ignition on and press >
It happens over and over and never goes any further into the reprogramming process.
I spoke to the guys at MADS/Smarty and they said it could be "Insufficient voltage (you need 12.6v+ at the ECM), Corrosion in the
OBDII port, wiring problems from OBDII to the ECM, or the ECM itself"
The Edge CTS Monitor will power on and ask me what type of truck it is, I choose Dodge/Chrysler then it takes a while to boot up but it doesn't display the correct PID options like boost, trans temp and rail pressure.
I spoke with the people at Edge tech support, I connected it to my computer and they read the information off of the CTS itself. They are saying it is not getting good communication with the truck and it is going into a Default monitoring mode after trying all the other known dodge protocols ... this default mode works fine, but only lets me choose from a limited list of functions to monitor.
Sometimes the CTS screen sort of flickers, not sure if that is related or not.
I checked the OBDII port and so did another guy here from the forum,
Everything looks good, no wire issues or corrosion and all the pins are pushed in.
The truck runs fine, no check engine lights and no problems otherwise.
The previous owner said it was never programmed and the ECM / computer is all stock.
I took it to autozone and they connected to the truck with no problems
Displayed all the truck info, make model engine 4wd, etc.
Checked for codes, there wasn't any.
Where should I look next?
Is there any known problem areas in the wiring harness? (Connection points or wiring itself)
Specific ground locations?
Someone has to have come across this issue in the past
Tori
08-24-2015 07:24 AM
ironbrew
07-01-2012 09:14 PM
FishBio31
11-01-2010 09:30 PM
FishBio31
06-17-2010 05:26 PM
mtman86
0
05-24-2010 12:39 PM
