smarty vs. bullydog (and hopefully) vs ppe...real info FINALLY!!!
#168
This is what should be happening with the TNT/r, not 3400rpms
http://www.youtube.com/watch?v=QQwlBGWC7BA
#170
This a good example of a label reader.... Not to put anybody down.... You are stating that someone, somebody or you read something that the TNT/R fueled all the way to 4000 RPM... Well that's why we tested it on a dyno to show you where it fuels... So in conclusion it does not fuel all the way to 4000 RPM like you think or was told... That's why in the dyno graphs the power levels are dropping fast after 3200... Of course you can spin it up further but if its not making power why bother.... not doing any good in those RPM ranges..
#172
I've run all (3) of these downloaders
1st,..I had good,.. not great customer service from each. Pls keep in mind,.. and I think everyone can relate to the difference between Power and Driveability.
PPE- An extraordinary product with outstanding power and diveability. I took it head-to head against the S06 Smarty and it was stronger than the 4.2 but not as strong as the TNT or the TNT-R. Not a huge difference and consider it did NOT have Torq Mgt Delete. Also it is now a 3+ year old PPE HOT program. I never had problems of any kind with codes on my 04.5 with it.
BDTD- This programmer was run with various CL programs and lastly with the vaunted Scary Larry program. Erroneously I and others were told this program would in fact work on the 04.5,... it does not. Will it run with it,.... yes but not with anything more than moderate performance and not even close to PPE Hot or Smarty TNT-R. This is not to say on the right truck (an '05 auto) this program is absolute killer. I did have code problems and more smoke with the BD programs in moderate driving than the other two programmers. Again, it may well be due to my year truck or mods on my truck,... I don't know for sure so I don't want to color someone elses opinion without knowing for sure.
Smarty TNT-R- For both Power and Driveability I like this downloader best on MY truck. I had NO code or problems of any kind with this product.
A couple things for users to keep in mind. For each year 3rd gen truck there is almost a different ECM program for each MONTH of each year model!!! What???!!!! Yes! Ck it out with a DCX parts dept and you will find this to be accurate. This is why these products DO NOT run the same on seemingly like year trucks. Then you throw into the evaluation mix a host of other mods and you a great variance in power and driveability between products.
I would not at all doubt the claims of any user of any of these products as you cannot match their full setups so quite likely most of the claims by users is accurate. This is NOT apples with apples so give your diesel bros a break and admit you only know what works on YOUR truck as they know what has worked on theirs.
Good luck to all in your mods.
#173
You all are loooking at this wrong.... What we stated was the Smarty TNT/R tune that is such a secret doesn't work... People wait and hope that they can get this special "HIGH PERFORMANCE" tune... but when tested against other tunes made by Smarty and BullyDog they fall flat on there face.. How can a Two year old BDCL tune outpower and perform the Smarty TNT/R tune... There should be no way possible if people are testing it and have R&D with it... Where is all the R&D ???? You hear people state all the time I don't have the mods for that... Why not ???? It's no stronger than the regular tune. But they only give it out to a few to make people think it's way stronger to keep people wanting and asking for it.... It's the good ol' Smoke and mirror trick... That's what we where origionally stating... but then it just led to more and exciting things...
By the way, who is the WE you so strongly represent, "you and your bullydog" or what?
Your points have been made. Why don't you move on to how fabulous your tires or your shocks are
#174
I think this is useless comparing the extreme tunes from Bullydog and Smarty when the trucks being used don't have the full range of supporting mods.I can gaurantee that a mildy modded truck will make less power with the tnt/r than say an older beta tune.I have ran almost every Smarty tune and have felt the differences betwen them as the suppporting mods on my truck have been upgraded.The TNT/R had my stage 2 pump hanging on by a thread with RP recovery,where as the beta's had smooth and continues ramp up of RP.When I went to the stage 3 pump the RP on the tnt/r was more linear in ramp up and does not have the tremendous pressure drop and slow recovery,which inturn made the power that this tune has to offer.
I'm not saying one is better than the other,I'm just saying that depending on what tune you are running from BD or Smarty, the truck needs the right mods around it to work.To say a particular tune made from brand x is better than brand y is completely misleading.I think the only way to declare which is truely tops in hp is to test on trucks that have all there is to have on supporting mods,dual pumps,big twins,big injectors and see where the numbers end up.I would fully respect the numbers then regardless of which programmer came out on top.But for now I think the lesson learned is there are different tunes form different companies that may work better on your truck with the set up you have,nothing more,nothing less.
#175
OK Guys, this one got completely out of hand with people insulting each other and members that register here ONLY to Flame people. The forum rules are pretty specific about this kind of behavior and I had to ban one individual because of it.
Post information and discussion, leave the playground antics out of it or I will close this thread down.
#176
DTR 1st Sergeant
I realize this isn't a democracy here, but there has been little of real informational value to the thread... a lot more of the playground antics as you put it. I vote to close it anyway...
#177
I totally agree with the final consensus. This isn't gonna get anywheres because ppl read things the wrong way when they're fired up. I'll stick to my guns, ya'll stick to ya'lls, whatever you pick should make you happy, not anger you because someone says their Smarty or their Bullydog is better.
#178
Only people that dyno there truck knows the fueling pattern. No need to turn 4' cause most I have talked to or read there post. All the programmers fuel to bout 3200 and after that they really didn't gaon much.
This post has went 20 different ways since the begining. I agree for once on closeing it also. Cause this still hasn't solved anything but creating bunch of babies here in this post.
Larry I vote to close it also. I'm tires of seeing same post on every page of this thread
#179
^ Now you wouldn't know that now because the Smarty made your truck surge. Why would Marco release a 4krpm tune that wasn't intended to be turned to 4k? I never said it would affect peak horsepower, I believe I said that too in another post, but I still believe that it would affect track times.
