Smarty Updates From 10/01/07!
#62
Yeah, but the Torque Management is giving me problems though.
On Wild TM:
It also tried to continue to fuel when off the throttle. I know it tries to continue to fuel, that saves the turbo, but this was crazy.
Pulls crazy hard though (after the first gear TM problems).
-Erick
On Wild TM:
-Erick
#63
im starting to think that part of the rpm hanging is due to the plunger inthe fcu retracting slowly...
it takes it a sec to blead off the volume of fuel traped behind the piston..... least thats my theroy....
#64
I lost my key counter and When I hit 110 check engine light comes on and map sensor voltage to high and overboost code. Top speed hasn't past 110 with knew software and has trown codes and has lost key counts.
I REPEAT IF YOU HAVE FIRST RELEASED TOP SPEED LIMITER PROGRAM DO NOT USE IT!!!!! Marco or Bob help
#65
#66
I hit 110 today. Truck defueled and threw to dtc's When I was clearing the dtc's I checked the key on counter And it was at 3
I'm waiting on a answer from bob or marco to help me
#67
I think im gonna keep using the key start trick to go faster then 112mph.
I'm gonna wait till the production version on beta comes out plus speedlimiter and 4000rpm limiter.
Does anyone have the first version of the Smarty downloaded on their computer? That way I can return it back if I dont like it.
The OG version + MP8 works great on my 04
#69
for everyone with the 4.4 beta, i know how to get rid of the limiter and keep your beta program. all you do is go to were it ask for your tire size i think the lowest it will go is 20.2 or something like that. put in 18 and it will set the lowest allowed on its own. this will throw your speedo off almost 15-20 mph on the stock truck tire, wich means when the truck wants to shut down at 100 you are actually going 120. and the taller the tire the faster you can go before the factory shut off. plus on stock tires 50 miles of driving (off road of course) actually only registers as 32 or so, and with bigger tires the difference would be even greater.
#71
brett
i had to edit what i wrote becuase i dont want people to think thats what i do!
#72
Yep!!!
#73
seems to me that Bob and Marco came through here pretty quick. I don't have a smarty or even a truck yet!!! I can say I'll be buying a smarty for sure when I get my truck, not just because its what pretty much everyone on here has (or wants if they don't have), but because of the customer service and support I have seen on the forum from those two guys. Thumbs up to Bob and Marco!
Jason
Jason
#74
#75
