Smarty update and Vista
you can you use vista but it takes some time to find the program your computer will let you use. I used the 7z442 that is 818 mb is the only one that worked on my new computer
I haven't tested the program nor the inf file with Vista, but I believe it should work. Probably will have to bypass some of the security screens due to the unsigned driver and do a force install.
If the Smarty program doesn't run just go into the properties and change the compatibility mode to XP.
MikeyB
MikeyB
Anyone getting it to work on Vista 64 bit? It is taking forever to install the driver and I couldn't do a force install. Vista went ahead and started installing a driver without asking me. Hope it works but it has been running a long time.
nevermind, of course it worked after I typed in the above.
JThiessen
20
01-16-2009 01:54 PM
justutt67
10-26-2008 07:33 PM
gsmopar
08-09-2007 04:34 PM
ramtd02
05-09-2007 10:48 AM
