Smarty update problem?
Old 12-06-2008 | 10:52 PM
osiris's Avatar
So I am trying to update my smarty to TNT everytime I try to send it to the smarty it says ftd2xx.dll not found... what else do I have to do to get this found and update smarty? thanks guys
Old 12-06-2008 | 10:57 PM
coreydr2003's Avatar
Where did you get your smarty at?
Old 12-06-2008 | 10:59 PM
osiris's Avatar
i got it from farmboy diesel 2 years ago.... i was able to update to revo no problem but that was with xp... i now have vista
Old 12-06-2008 | 11:10 PM
Sorry i would know how to do it, i run dont run standard programming, the only reason that i aske where you got it was i know that smarty would let you if you bought from like ebay, but thats not the case, sorry i cant help im sure someone on here will be able to help goodluck
Old 12-07-2008 | 02:21 AM
JCLeary's Avatar
Did you extract the file? The download is zipped, and you'll need to extract it to be able to upload it to the Smarty...
side note-Vista sucks. I have it on my laptop. Wish I had XP...
Old 12-07-2008 | 02:34 PM
Bob Wagner's Avatar
you dont have the driver installed
Old 12-07-2008 | 06:32 PM
osiris's Avatar
where do i install the driver?
Old 12-07-2008 | 06:50 PM
mikmaze's Avatar
onto the computer you will be using for updating the smarty, it is a driver that tells the computer how to use the device when you plug it in. It is on the mads site, along with the newest software. and directions.
Old 12-08-2008 | 09:05 AM
osiris's Avatar
hmm I had everything installed I just forgot to install the driver to the smarty thanks guys...
Old 01-07-2010 | 12:07 AM
Big Horn's Avatar
I have everything downloaded and my computer will not recognize the smarty as new hardware so the "found new hardware wizard" will not open. Is there another way to install the driver? I get the FTD2XX.DLL not found message and I don't know how to get the cdm file loaded. I have it unzipped already but I am open to suggestions on how to get it installed. Thanks.
Old 01-07-2010 | 01:23 PM
MikeyB's Avatar
Can load the driver by using device manager. Plug in the Smarty to the computer through the USB cable and go into control panel/system/device manager. Looked for a unrecognized USB device and open it. Then go to the driver tab and click on update driver. Select the correct path the the Smarty driver (dll) file.
MikeyB
psd tuner
05-10-2008 11:56 PM
blwnsmke
02-03-2008 08:47 PM
josterbauer
10-16-2007 10:33 AM
straight_six
08-05-2007 10:32 PM
MnTom
08-26-2004 12:19 AM
