Smarty Tnt Owner's Look At This.
just recieved some info i thought would be helpfull to other's. the smarty TNT'S TIMING DEGREE'S are as follow's timing# 4=16* max,timing# 3= 18*max, timing#2= 21* max,and timing# 1= 12max.ALSO take note added pressure adds approx. 3-5* more.same with water/meth if you use a 50/50 mix less if you use the windshield waher stuff.
TNT Timing Degree's
#4=16* max
#3=18* max
#2=21* max
#1=12* max
ALSO take note added pressure adds approx. 3-5* more.same with water/meth if you use a 50/50 mix less if you use the windshield washer stuff.
Easier to read like this, thanks for the info
#4=16* max
#3=18* max
#2=21* max
#1=12* max
-PowerWagon-
12-30-2008 01:06 AM
wyocat
26
06-23-2008 01:39 PM
jmccart
06-20-2008 03:29 AM
TORQUE BEAST
13
05-09-2008 02:31 PM
molalla1ton
04-16-2008 01:08 PM
