Smarty speed limiter question
For the first time since I got the smarty, I tried to test out the speed limiter the other day. It governed at 108. I went back to stock, and then loaded a different software yesterday, and it still governed at 108. Why doesn't it go any faster?
Did you adjust the speed limiter in the revo options then press the > until it
says "writing memory". Then reprogram?
Also, you don't need to go back to stock then load the program everytime. You can load smarty program over smarty program all you want then go back to stock.
You have to load the option first, then the sw# of your choice. The options will not take affect until the sw is reloaded.
Hope that helps.
Hope that helps.
Don't feel bad, I made the same mistake when I first got mine but figured it out trial by error. I love the Smarty, but their instructions in the box are poorly written for a someone new to programmers. It took me a while to figure out too that the timing levels weren't in sequential order.
SCCSURF
01-19-2009 06:46 PM
mcolectd
06-13-2008 02:42 PM
ARAcummins
10-24-2004 09:30 PM
Ttexas25
31
09-30-2004 08:48 AM
