Smarty Settings
After your clutch is broken in I suggest you start with the lower levels on the odd numbers such as 3 or 5 then work your way up from there. The odd numbered programs have the advanced timing and the even do not. Watch your fuel pressure on the higher levels as on the stock pump I was able to draw mine down to almost 0. Good luck roll some coal....
nvr-enuf
04-23-2011 12:43 AM
D.Wiggs
31
08-30-2007 02:48 PM
BigDan
43
09-17-2006 02:50 PM
