Smarty S06-POD.. BOOOST!!
03' 2500, HE-351 upgrade, adj elbow,5 speed, 4x4, 4.10 gears, 265-70-17 tires.
Ok, just got the Smarty Friday. First thing I did was correct the tire height. It was set to 33.75" tires and had my speedo 6 mph off.
Then I set her to SW-8 and headed home. After the clutch slipped in 5th gear doing about 35, , I backed it all the way out to 50% of stock and drove it about 15 miles to check mileage. While the mileage was better, the truck couldn't get out of it's own way. I could see using half power on a long trip not pulling anything, but other than that, no.
I now have it on SW-7. Good power, no clutch slip and getting 20+ mpg.
When I swapped my turbo for the newer/larger HE351, I installed a boost elbow and adjusted it to top out a 29-30 psi.
HOWEVER, since installing SW-7, I am exceeding 40 psi. I am trying to decide on adjusting the elbow accordingly to get back down to ~ 30 psi, or backing the tune down to 5 or six and seeing what happens with the boost.
Anybody else had similar happen and if so, what did you end up doing? De-tune via Smarty, or adjust the boost elbow to release sooner?
Performance & Accessories Smarty S06 PoD tuner $600
rider225
3rd Gen All Products
07-29-2015 08:24 PM
Performance & Accessories Smarty S06 PoD (03-07)
VaultRam
0
12-29-2014 11:59 PM
wildcat
08-12-2009 12:22 AM
BrokeSolid
21
02-03-2009 10:36 AM
