Smarty S-o6 fuel mileage setting
Old 06-12-2008 | 01:52 AM
JP-4.5's Avatar
I am also trying various settings with the TNT Revo attempting best MPG.
Currently trying Level-1 Timing-3 TM-4 RP-4
I like the quick throttle response.. Once you learn to drive with light foot it takes very little throttle to get the truck moving. The Timing on 2 was very smokey on my truck. I think it is from the larger turbo. The higher TM and RP I think helps spool the turbo a little quicker and only has a small puff of smoke when driving cautiously..
I have been getting low 18's last 2 tanks.. with level-3 Timing-3 TM-3 RP-3
I have only had level-1 TM-4 RP-4 for a 1/4 tank but looks to be doing better than previous. As long as I can keep my foot out of the pedal.
I will run this for a tank and then try lowering TM to 2 and leaving the RP at 4.
It is great having the adjustments to work with each truck for best results.
Thanks to Marco and Bob..... Great Product!!
Old 06-12-2008 | 03:13 PM
Jason_K's Avatar
how does your rail pressure look on rp 4? mine would run dangerously high on rp3, i havent even tried rp4 yet.
Old 06-12-2008 | 07:38 PM
JP-4.5's Avatar
smoke19d,
No rail guage yet installed...
I had been running the Beta 4.4 for quite some time prior to the TNT Revo being released. I believe the beta 4.4 had very agressive rail pressure also.
What are you running for filters for your fuel? I really believe the low micron filters have helped my injectors over the miles.. 96k When I go to check valves at around 100k I would love to do cam, springs and injectors (F1 1.8) if I can come up with the $$. I would liek to do them at different times to break up the cash spent but it makes som much sense to do when it will be apart anyway..
This is the 1st time that the truck has felt similar to the Beta 4.4 I had been running. With the rail pressure up my truck is not smoking like it had been. I almost want to try Timing 2 again with RP-4 to see if it helped the smoke I saw on that setting.
Might try..
Level-1 Tq-2 Timing-2 RP-4 for my drive to work and back tomorrow..
Old 06-13-2008 | 12:04 AM
Jason_K's Avatar
smoke19d,
Might try..
i only have the stock filter, that's why i took the rp down to 2. i was hoping to get on a dyno soon and i would like to run rp3 or rp4 but not at the expense of a blown injector. on rp3 i was cruising at 20,000 and that was too high for my liking
Old 06-17-2008 | 06:50 PM
Tacsavage's Avatar
That would make me real nervous running that much rail pressure all the time. Especially with the warnings from Marco on his site about it. You may be suprised when you do get a rail gauge to see how high it is running. Especially at cruising speed with a little throttle, it would probably be over 20,000 easily. Tac
Old 06-17-2008 | 06:53 PM
Tacsavage's Avatar
Originally Posted by smoke19D
am i hurting anything running timing 3 w/ stock sticks? i know mads site says that timing 3 is for huge injectors but the truck seem to run pretty good on that setting.
It is just less timing than default timing. May not be best overall for mileage or power. It shouldn't hurt at all I wouldn't think. Maybe someone else in the know with chime in. Tac
Old 06-17-2008 | 08:36 PM
Patriot2500's Avatar
Not to hijack, but could you use the same levels on a Smarty S-04 to get the best fuel mileage?
Old 07-05-2008 | 03:54 PM
HarleyHauler's Avatar
Well folks, I tried some new settings and got some less than desirable results. I used the settings of SW#3,TM#2,TIMING#4,RP#2,WASTEGATE OFF and turned a whopping 15 MPG calculated by hand. I drove a 1235 mile round trip from San Antonio to El Paso. Now I know that speed can make a difference, and a good portion of the trip was made with the cruise set at 85 mph (I know, you may say 'Slow down and it will help' but have you ever driven that stretch of I-10???).
Has anyone seen any other settings that may increase my odds of better fuel economy?
Old 07-05-2008 | 11:04 PM
annabelle's Avatar
I know it's hard to do in the 80 MPH zone after Odessa, but when i set the cruise at 1800 RPM I get about 24 MPG when I go between El Paso and Austin.
Old 07-06-2008 | 01:23 AM
DaveB.inVa's Avatar
You're fine running that. That setting actually reduces timing some as larger injectors effectively advance timing.
I'm not running the REVO software but am running stock TM and the aftermarket injectors tune on SW1 with stock injectors. I figure I'm sorta splitting the difference between stock timing and stock injectors tune set on SW1. By that I mean my timing is more advanced than stock but less than it would be if I were running the stock injectors tune. It does pretty good, I hand calculate over 20mpg regularly.
Mine is all for smoke control and it does a good job of it. Stock TM is far from stock but not as touchy as mild or above.
Old 07-06-2008 | 06:42 AM
MikeyB's Avatar
I'm getting pretty good economy with the current setting. Level 5, TM 1, Timing 4, RP 1 and Wastegate Off.
MikeyB
Old 07-06-2008 | 02:12 PM
MikeyB
MikeyB - what do you consider to be pretty good?
Old 07-06-2008 | 02:15 PM
I guess I need to slow it down. I was running at about 2200 to 2300 RPM most of the way. Timing was important though, so maybe next time I can keep it under control.
Old 07-06-2008 | 03:36 PM
MikeyB's Avatar
16-17mpg for around town. Haven't done much highway driving lately.
MikeyB
Old 07-07-2008 | 05:42 PM
MikeyB
Not too bad, seeing as I was getting 15 on the highway!
BTW - I used to live in Tomball and my son was born there. I lived in Rosehill if you know the area.
zylberberg
06-17-2008 01:44 PM
Twogun
05-19-2008 08:07 PM
rammv
13
01-16-2008 09:06 PM
samgovol
01-07-2006 11:33 PM
zmock8
04-14-2005 11:34 PM
Quick Reply: Smarty S-o6 fuel mileage setting
