smarty question
smarty question
i have a smarty now, so i took the BDDL off the truck. i havent installed the smarty yet, as i did some reading and not sure what to do. when i install the smarty, do i tell it what size my tires are(315's) or not, cause i had the speedo flash done for that size all ready.also i am not sure where the TST box should be in setting.no timing, auto timing, what number work the best etc.
If the ABS "pionion factor" has already been programmed then it should stay programmed and there is no need to change it with the Smarty.
You have a couple of different ways to stack the TST and Smarty. If you run Smarty Even #s (No Smarty Timing), then you can run the TST with normal 12*/15* Auto Timing. Set TST on low settings to start with and go up one setting at a time until you find optimum.
You can run the Smarty Odd #s (With Timing), the set the TST timing to 0/3* Auto. Set TST on low settings to start with and go up one setting at a time until you find optimum.
You can play with different Smarty #s and TST settings just remember to keep TST timing low if you are loading Smarty #s with timing.
I currently run Smarty Wild TM for Aftermarket Turbo stock Injectors. For daily driving I load Smarty SW #5, TST 05TT program, set 3* Auto Timing and TST HP/TQ at 2/0. I also have my EZ on Level 1 for a little pressure since my TST does not have Rail Pressure option.
thanks alot for the info, great, i have lots to do now to try out the new programs. i have my EZ on level 2, for added pressure. been like that since i got it, never change it.
Well my EZ which only has 3 levels has been on one of them for nearly 3 years now. It has been stacked with Juice, HOT Juice, BDTD w/CL, TST and Smarty. On the dyno it only adds maybe 10-20hp, but on the track it helps the bottom end a lot more than that.
You have the basics of how that combo can stack, just takes a lot of tuning at different levels to find the optimum. Good Luck!
thanks, i know the old try and try different settings, cause every truck is slightly different. i don't really need any big power right now,doesn't help in the winter, but i miss playing.
skydiver41
03-23-2012 08:51 AM
stock03
34
04-21-2011 07:40 AM
jmccart
11-22-2007 07:43 PM
Mike Holmen
05-21-2007 10:21 PM
