Smarty + large injectors
I just ordered up a smarty and now im saving up for a tranny and other goods. I do not really want to stack box's and was thinking of running large injectors to make up the difference, like fluxs 3's or bigger. Some people say I will need some pressure for fueling on the top end (I need to be in the 11.85s-12.00 in the 1/4) What are your guys opinions on this? Is it possible to get the times I want without stacking. I will more then likely be useing nitrous also. thanks
There is a SMARTY program for aftermarket injectors over on Mads Electronics website. http://www.madselectronics.com/DLWelcomeS06A.html
If more is needed I would go with a Edge EZ or a TS MP-8 pressure box.
MikeyB
MikeyB
im not shure yet, I keep jumping back and forth...prostreet 66, sps66, or the silver bullet. im leaning towards the bullet...dont think im doing twins. What would keep my egts lower, A pressure box or big injectors? Thanks for replys
You would be surprised. I had to big up some friends when there Ford Exspedtion broke down. It pulled fine for me and the temps never did go over 1000. That is pulling it on a trailer for 4 hours.
If you want to go real fast talk to Barry @ NADP in Edmonton. He will probably tell you something like this. Dr Performance Predator, PPE Exhillerator, flux 3's (or equivilant) sps 66, stage 2 cp3, single (small) shot of nitrous, bd intercooler etc. And of course a full race tranny
Kevin
Kevin
Kevin
Kevin
no towing for me, just my motorcycle in the back and some sledpulls..............SOLVERADO....what were your egt's when you dynode 670hp?? And while im at it. I ordered my smarty from D.P.P. and it says 03-06....I could have sworn that Marco said the 06 smartys are a tad different because they require more memory space?? Thanks for all the help guys
Morkable...not tryen to be a smart mouth by any means but what is your definition of real fast? I dont need to go faster then 11.85ish I want to race quick diesel...12.0 index. I need my truck to be able to go a tad faster then a 12 incase air quality or altitude is crap. And if im runen faster then a 12 I will detune. thanks for your imput
Dont worry I wont take it as smart mouth, that combination will give you low 11's. If you run the combo that I have you will run low 12's and still be able to tow a 5th wheel to the races. It wouldnt take very much for me to be in the 11's, small shot of nitrous and I would be there
Kevin
Kevin
