Smarty killing my speedo?
Recently on and off my speedo has been not working. Sometimes it works sometimes it doesnt. The ABS and BRAKE light also come on when this happens. So far it has done it twice then kinda cleared itself up. It was not doing this before I installed the smarty.
Not always. I use the Smarty to check the codes. I ran into one being thrown due to an alarm system issue for my cruise control that did not show a check engine light.
Mine does this all the time when it gets cold. I think it is a bad connection in the sending unit. it seem to be around 40 degrees when I sat to see the problem but if I drive around for a bit the lights go off on the next start.
NJMurvin
23
04-25-2004 01:21 PM
Crimedog
01-20-2004 12:40 AM
