Smarty Junior REVO 40-70-100 hp software
Bob W. . . . . .thanks for sending Revo SJRV507ADR12A for my JR. I updated from SJRV503DD211B. Nice to have TM and TQ ***** to play with,not real clear on which setting yields what, likely my fault. I need to read more threads. I do miss my smoke though. Old program #1,2 or 3 made pretty good smoke, new program #2, TM#2 and TQ#2 about half as much smoke. Still searching for best settings.
Guspsoras12 (03-21-2020)
I actually started with catcher 2 and defaults for timing and torque, Low smoke, not as much grunt. That's when I went back in and set them both to #2, thinking default was even lower than the low smoke #2.
You suggest then injection timing #4 and 0 are about the same and Torque will need me to load a few and try them out?
It remains unclear that torque managemnt settings are shown in order. If I read MADS correctly TM=0 provides the lowest level of TM, "most smoke" and #4 is the highest "least smoke". But yet if I read the comments next to each setting I get confused.
I need a decoder wheel for injection timing and Torque management.
TM? more smoke/morepower 0, 1, 2, 3, 4 less smoke/less power
Injection timing I have no idea how these might order.
I can't wait to try REVO for Jr.
However, the explanations are a little unclear.
Bob, could you list the settings from least timing advance to most timing advance? I'm having trouble determing what setting has the most timing advance.
The torque management settings are also a little unclear. The instructions state the higher the number, the more torque mangagement remains. I was under the impression "#2 Mild" was the default setting in Jr. If that is the case, what is "#0 Default"?
I am confused. Please help!
From least to most in numercial order -why that would make too much sense. Thats why it can't be done. It's kind of like the who's on first ,what's on second routine.
Hi Bob,
I have a beta 4 version of the JR. and it's producing more HP on level 2 than it should. Does this Revo update solve this issue?
BTW---Love the product, but my TC doesn't.
If I undertand this correct (?), the new revo software is a means to turn down the original software. None of the tuning makes more HP than the original software does it?
