Smarty Jr, now not enough air SOOOO
Old 03-09-2008 | 05:01 PM
DZLROKET's Avatar
I did the cold air mod with the toilet flange installed in bottom of stock air box and tube to the front bumper, and I am STILL pulling the filter minder way into the yellow with just a few power runs.
Could it be the Amsoil filter?
Old 03-09-2008 | 05:30 PM
LFD2037's Avatar
I saw a post somewhere that the guy took his filter COMPLETELY out & it still sucked it down. I wouldn't go by that piece o junk @ all.
Old 03-09-2008 | 05:37 PM
rip 112's Avatar
The filter minder was intended for stock airboxs, so when you put a higher performance intake or filter on it you can expect the thing to be useless because aftermarket intakes pull more air through at a different velocity.
Old 03-09-2008 | 05:44 PM
torquefan's Avatar
It can't be useless, because it is spring loaded, and the yellow won't fall down on its own or by magic. It is telling you that there IS a pressure drop between the intake duct and the outside of the airbox. Period. You can replace the minder with a vacuum gauge and it will tell you the same thing. The question is whether or not you can find a filter and housing that will flow enough to cause no restriction.
Old 03-09-2008 | 06:15 PM
DZLROKET's Avatar
Correct! It was pulling down before I added the cold air/ram mod. Started when I added the smarty. It's a no brainer that I am making more horsepower and adding more fuel so I need more air! The mod added air to the bottom/intake side of the air box but the Amsoild filter is still the most restricting part. I will try and experiment of removing the filter and doing a few runs and post results.
Old 03-09-2008 | 07:50 PM
chipmonk's Avatar
ding ding ding...... a winner! it often doesn't even work in the stock airbox, with the stock filter. but there are some that will tell you that it must work, because dodge wouldn't put something like that in for no reason at all right? how many people have never had their 'water in fuel' light go on, even when you can see water was in your canister, when you drain it?
Boatnik
08-05-2007 10:09 PM
PEAKSTRYDE
05-16-2006 07:56 PM
MiniC
01-07-2005 09:12 PM
Journier
11-02-2004 03:04 AM
natstayl
07-21-2004 06:07 PM
