smarty jr egt
Increasing your timing might help. EGTs seems really high for just a Smarty. Are your injectors in good shape? What are all the gauges reading (RP, FP, etc.)? What are your EGTs on each level and stock? If they're high no matter what, I would guess that some of the injectors are stuck open.
Only have ran level 2 and 3. Rp is normal. Max of 21k. Egt is fine till I stump on it. Then I see the big numbers. I don't think its injectors cause she runs clean. No white smoke or extremely sooty exhaust. Idles fine aswell. I bought the truck used as a repo. Maybe he put bigger injectors without increasing turbo size. Or maybe my probe is bad
I would say your last two options would be why your EGTs are high. Your probe should be right above the flange on the exhaust manifold, back just a hair. You could pull an injector and check the nozzles. If they truck already had an aftermarket lift pump when you got it, I would say you have larger injectors.
2005 3500 4x4 running smarty jr. S/B intake with CFM horn. Stock otherwise. 32 lbs max boost have got 1250 EGT pulling hill with loaded toyhauler. Probably larger injectors.
probably right, I put smarty back to stock and still hit 1800's with added timing. Something isnt adding up. I dont think there is a hung injector cause it idles great with no white smoke or anything. Guess the only way to correct it would be bigger turbo or try a mechanical egt gauge instead.
I would try another EGT gauge first!
What shape is your air filter in?
What kind of boost/EGT's do you hit in 100% stock mode?
But use caution, 1800° and the added timing will make molten of pistons in short order.
Sam Turner2
27
12-24-2008 09:52 PM
jmccart
03-18-2007 10:03 PM
jmccart
14
11-20-2006 06:45 PM
