Smarty & Edge attitude
I'm going with a Smarty from a Edge Hot juice w/ attitude. I wondered if you can keep the attitude monitor for EGTS???
TIA
ontun
TIA
ontun
Well you have to leave the Juice/Attitude completely installed to be able to read the EGTs from the Juice pyro sensor. You can do this and even run the stack although I don't recommend it. I did not like the combo on mine. You could probably just leave the Juice/Attitude on stock without any issues, this will also give you boost fooling which is a good thing. Just my .02.
Wheels
So if I leave my box on (0- stock) everything should be OK, will the Smarty detect the edge box and flip out.
As Bob said the Smarty will be fine. You can use the Juice/Attitude and you will certainly be able to tell the difference. I would set the Juice/Attitude low boost fueling to lower settings on all levels(avoid the extra smoke) and give it a try. You will benefit from the boost fooling that the Juice/Attitude will provide on any setting. The HOT 180 setting will smoke a bunch and will have a little timing rattle, but won't really hurt anything with your mods. And it will go fast.
I tried it for a day. My experience was that timing was out of wack too far, but it did run. And playing with settings found a couple that added fair power. I did not plan on running the Hot Juice with it or the BDTD w/CL that I tried. The BDTD was much better with the Hot Juice, but I was just waiting for my TST to get back and only ran that for a couple of days. Thats why I said I did not recommend it.
blue2002
11-24-2010 11:46 AM
chrismez
09-26-2005 01:47 PM
Hoss
13
06-18-2004 06:14 PM
