smarty downloading problems
Old 12-09-2007 | 09:14 PM
Merritt's Avatar
I have unzipped the CDM -2.00 file, downloaded the SmartyUSB file (all in a separate folder on my desk top), and downloaded the "Smt4V411AD411C47" file into the folder as well. Now, when opening the SmartyUSB file - and attempting to open a file to send - it's saying that the file is not a smarty file.
Also - I already linked the smarty programmer to my computer.
Any help I can get would be appreciated. Thank you!
Old 12-09-2007 | 09:21 PM
CalDodge's Avatar
I had the same problem, you need to unzip it so the program can see it.
Old 12-09-2007 | 09:37 PM
Merritt's Avatar
Problems with the Smarty download
I did unzip the file - however, when I try to download it to the Smarty Program so that I can send it - nothing shows in the folder...any ideas?
Old 12-09-2007 | 09:41 PM
CalDodge's Avatar
I had to move it to another folder by itself. Then it loaded just fine.
Old 12-09-2007 | 09:42 PM
Bob Wagner's Avatar
The .7z file needs to be extracted to a .smt file using THIS SOFTWARE
http://7-zip.org just run the file for your operating sysytem.
Thanks
Old 12-09-2007 | 09:44 PM
10mm's Avatar
Smile
The only way I can get it to work is to download the file I want and then make a new folder with the same name as the file I just downloaded and unzip the file into this new folder. Once it is unzipped it should have a .smt at the end of the file name. With the smarty usb go open this folder and that file and it works. If I name it some other way or don't do it in that order I have problems.
Old 12-09-2007 | 09:51 PM
Merritt's Avatar
When you say "it" are you talking about the downloaded file -Smt4V411AD411C47 (software update)?
Old 12-09-2007 | 09:56 PM
CalDodge's Avatar
Yes that is correct, it=Smt4V411AD411C47.smt. Sorry about that
Old 12-09-2007 | 10:05 PM
shortbed rv's Avatar
Smarty folder needs the USB, CDM, 7ZIp and SMT. Be sure to click on 7Zip and select run. Then right click on the smt file and select extract here.
hope this helps
https://www.dieseltruckresource.com/...=update+smarty
try this thread for some good infor.
#2 only
09-04-2008 02:02 PM
moparman13045
05-08-2008 07:08 PM
GOT BOOST?
04-07-2008 03:10 PM
JRAPTOR04
02-14-2008 02:32 AM
Kevin Krieger
05-10-2007 10:35 PM
Quick Reply: smarty downloading problems
