Smarty defaults
Smarty defaults
Does anyone know what the defaults for the Smarty are at the various catcher levels. I am running Revo and have it at SW3 right now on my stock 03 SO. But what would that correlate to with the timing, TM, and RP settings? Yes I have searched for an answer but everything I see talks about changing the settings and nothing about the baseline. Maybe I am just misunderstanding the software.
Happy Reading! The info is all here;
http://www.madselectronics.com/
I didn't see anywhere where it speaks of what the modified TM, Rp, or timing settings are for each Catcher. Maybe you could be more specific as to where on the site it is.
Thanks Wildcat. Now for the follow-up. Are these settings standard for each Catcher level meaning as you move up each level do those items remain the same. And what is the difference in the addional timing settings. (Obviously it has more timing, but what number would it be?) I'm new to this thing and just trying to wrap my head around the whole system before I jump into altering any tables.
The explanation used to be on Mad's.... Here is Bob's website, This should explain it better, this is TNT, click on different products/softwares, the timing sequences are different;
http://smartypower.com/new/smartytnt.html
Here's the original;
http://madselectronics.com/DownloadS06PoD.html
Interesting to note that if you change to let's say, Timing=3 then Timing=3 for ALL Catcher levels, until you change it again.same goes for the rest of the settings.
In short, they are global settings for all the Catcher levels.
I don't know the actual numeric amount of timing, I do know that for TNT and TNT/R the following applies:
0= restore default. Even Catchers to 1 (Stock) and Odd Catchers to 2
1= Stock timing
2= Most timing
3= Less timing than setting 2, more than 4 or 1
4= Less timing than setting 2 and 3
So in order from least timing to most timing in TNT and TNT/R you have:
For Revo timing, it's like this:
# 0 - Default
# 1 - Stock
# 2 - for stock injectors (But advanced timing)
# 3 - for aftermarket Injectors ( less timing advance than # 2 )
# 4 - for fuel economy ( more timing advance than level # 2 )
So from least timing to most timing
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
