smarty cr updates
Old 09-19-2006 | 05:59 PM
Bob Wagner's Avatar
chris, what does the error messge say? error writing to memory or something else?
Old 09-19-2006 | 06:01 PM
cquestad's Avatar
error communicating I think...I could try again and see...it just takes 17 or 18 minutes to do so.
Old 09-19-2006 | 06:06 PM
Bob Wagner's Avatar
yes please do. I can send you a file if you could call me later 888 225 7637
Old 09-19-2006 | 06:09 PM
cquestad's Avatar
trying again now...I may have to call in the morning. Thanks!
Old 09-19-2006 | 08:11 PM
cquestad's Avatar
Bob,
The Smarty says "Memory Error" and the Computer says "Error on Smarty 0" and below that "Error Sending Data to Smarty" and below that I can chose the "ok" button.
I am sure this was caused by something I have done...or my infested computer that I crank out engineering on all day.
I also did not return the truck back to stock (remove SW5) before attempting to upgrade. My common sense now tells me I should have done that...but in the excitement to try something new...I spaced. I did not see anywhere in the instructions that said I had to restore the program...but it seems like I should have????
duh
If I plug the USB back into the Smarty it says " Empty Memory-Please Update "
OUCH! I guess I am the Beta for stupid people....
I will be back in the office all day manana...
505-379-2750 Thanks!
Old 09-19-2006 | 09:31 PM
Bob Wagner's Avatar
I will call you tomorrow. no problem and dont worry
Old 09-20-2006 | 05:32 PM
cquestad's Avatar
Thanks Bob, Marco, and Stefano for the quick and easy fix. I gues there was just a fluke thing...downloaded a different file...and it worked great!
Off to test the new version 3 software!
Old 09-21-2006 | 09:32 AM
tcr's Avatar
tcr
Bob,
I updated the new Mild TM program #2. The throttle response is sooo much better, the shifting w/ the auto tranny seems to be alot better, like in stock form. One thing I'm now noticing under hard excelleration is a popping from the engine, and when this happens the exhaust pops out a puff of black smoke, even while it's spitting out a real good haze of soot, it will pop out a black cloud or two, then keep on rollin'. Any ideas?? This is happening w/ the Smarty only, nothing else adding fuel.
Thanks,
Tom
Old 09-21-2006 | 09:34 AM
Bob Wagner's Avatar
Tom it sounds like you are draining the rail. Time for more fuel
Old 09-21-2006 | 02:30 PM
dodgezilla04's Avatar
I'm reading the install instructions for smarty. If i understand right, there are 10 levels to load into the factory ecm. these are not adjustable on the fly correct? so i have to load 1 based on the abuse I expect to dish out. is there one best suited for towing, and one best suited for fogging intersections, etc?
i love new toys.
Old 09-21-2006 | 02:48 PM
Bob Wagner's Avatar
try towing on #3 60 hp with timing should be much lower egts and better fuel economy
Old 09-21-2006 | 02:54 PM
thanks bob. egts are good now with my aftermarket turbo. before they were horrible.
say, where in washington are you?
Old 09-21-2006 | 03:03 PM
Bob Wagner's Avatar
just over the bridge in auburn
cquestad's Avatar
Heck...any level tows great...130 tows great on mine!
Old 09-21-2006 | 03:05 PM
with my race box on max , as soon as the boost builds past 20psi, the clutch lets go. towing or not. Looking very hard at the con ofe.
Quick Reply: smarty cr updates
