Smarty and Big Tires
Old 06-30-2008 | 09:43 PM
acman's Avatar
I have a stock 06 Megacab that I just installed a lift and 35x12.50x18 tires. What setting should i use for everyday driving ? Thanks
Old 06-30-2008 | 10:19 PM
hump's Avatar
Need a little more info....
What Smarty do you have? Sr. or Jr.?
Either case, I would not go over the 100 HP setting with a stock tranny.
Also, do you have gauges installed?
Old 06-30-2008 | 10:23 PM
snoyes's Avatar
Auto or manual? How big of a lift?
Old 07-01-2008 | 12:44 AM
kanuckle head's Avatar
With my Toyo mt's @ 35 & my built tranny I set the Smarty @ sw# 7 for every day driving sw# 3 for towing under 10K But I monitor the gauge readings
Old 07-01-2008 | 01:32 AM
JCLeary's Avatar
I wouldn't go over 60hp with those big shoes and a stock trans. I left my truck completely stock 'til I got my trans goodies...
Now I roll on Level 9 most of the time.
Old 07-01-2008 | 10:34 AM
paroxysym's Avatar
um did you use the smarty to update your speedo with the new tire size? with 35s and stock tranny i had mine on 90hp everyday. worked fine, was fun too. tc never shuttered or anything. now when i swapped trannies for the goerend, the fluid was alittle burnt.. but hey what do you expect. looked like it was the stock fluid.
Old 07-01-2008 | 11:18 AM
GlennRMK's Avatar
I just have the valvebody upgrade and I'm running on the 100 hp setting on the Smarty Junior. I don't beat on it, but everything seems good and the transmission doesn't act up. I am saving up for a Goerend triple disc converter though. Probably will get one in the next couple of months. I ran on the 70 hp tow setting till I did the valvebody.
I'm running 35" Toyo MTs and to get the speedometer dead on with the GPS at 70 MPH, I set the tire height setting at 33.25".
Old 07-03-2008 | 09:01 PM
acman's Avatar
I have the Smarty SR with a Fabtech 4.5" lift with 35's FCII stock evrything else.
Old 07-03-2008 | 09:02 PM
acman's Avatar
The Trans is Auto.
Old 07-04-2008 | 07:20 AM
mm73's Avatar
I run mine on 90hp with the smarty sr. and have no troubles at all. trans works just fine, but I dont go beat on the trans because I know what will happen. But as soon as I get some trans upgrades I will be running sw9.
Old 07-04-2008 | 10:18 AM
acman's Avatar
Should I use with or without timing on the 60 hp ?
Old 07-04-2008 | 10:21 AM
cbrahs's Avatar
i have 37" tires and run SW3 daily til I get a tranny.
Old 07-04-2008 | 10:29 AM
mikmaze's Avatar
what you need to consider is the level of torque management, pick one geared towards a stock truck and take it easier on the tranny, power comes on a bit slower, and gives a break during shifts
Old 07-04-2008 | 11:29 AM
acman's Avatar
what does the addidtional timing do ?
Old 07-04-2008 | 03:28 PM
acman's Avatar
Anybody now what the timing does for milage or performance.
Quick Reply: Smarty and Big Tires
