Smarty Beta V4.2 Dyno'ed
#31
#32
not to try and answer your question. but my 06 has a stock turbo/injectors/cp3 and put down 461hp on the standard smarty programming. this was not the hot version. my trk is also an auto trans. hope this helps you any. it would probably shock you if you have a superchips and went to a smarty. it should be night and day difference
#33
I am looking forward to the release of the hot programming I might have a big turbo by then. I may not even install a tst I have waiting around. I may just get injectors & a better cp3 and be done with it.
#34
well I can tell ya this programming is REALLY STREETABLE!!! I feel that the throttle sensitivity is 50% of the standard wild i was running!!
On the highway I hit 120 mph and egts with my cp3, injecotrs and little 62 pulling 51 psi boost hit 1400!!!! With the standard smarty, cp3, and injectors at 51 psi I was hitting 1600 by 100 mph. That is over 200* egt drop!! Plus folks I still have a cat and 60 gallon muffler I am gonna axe, so with stock restrictive exhaust and confident i am over 600rwhp, I hit 1400*!!!!
Also cruising egt's were steady @ 500-550* @ 70 mph. Standard program was 650-700. So there is also a 100-150* drop at cruise!!
Excellent work MARCO and BOB!!!!
Jon.
Jon.
#36
ok folks, back from work for a couple of days here, and a mileage update is at hand.
Stock gave me an average of 17.9 mpg w/ 35's
Wild smarty gave a avaerage of 18.8 mpg
first 3 tanks of beta smarty is 19.9 mpg, with alot of fartin' around and driving like a lemming (NATURES RETARD!!)
This 4th tank of driving normal!! Cruise set @ 65mph, I just hit 1/2 tank and have 622 miles on it! So i will fill up early too see what kind of mileage that gives me!! Keep it up bob and marco!!
#38
My truck does that too,, first half takes forever, then the bottom half,, vroom,, gone.. still should be good for a 1000,, give or take (now were you talking kms or miles)
Kevin
Kevin
#39
miles, I figure i will get a solid 800 miles (1280 kms) out of the full tank, just for clarification I am usually at the 450-475 mile (720-760 kms) mark at 1/2 tank on summer blend. Usually end up with 650-700 miles (1050-1100 kms) to a tank with the smarty (about 19 USmpg).
Btw, O/H usually reads 1-1.2 mpg high and right now is reading 23.4 mpg. Which makes me think i should be rollin in the 22 mpg range, but we will see when i fill up and calculate it!
#40
My 03 has allways gotten that kind of mileage, I have driven from GP to Medicine Hat on one tank before, allmost putting on 1400km on that tank. That is at 120kmh. If I go 130 it drops drastically. My last trip to Edmonton with it was for dyno day there, I used just over 1/4 tank to get to Edmonton from here, did 2 days of dynoing, around Edmonton, and drove back to Whitecourt before filling up.. So I cant even imagine how good it would be if I were to run the smarty.... I hope to be able to try on day.. I have the smarty coming,, (hopefully next week it will be here)
Kevin
Kevin
#41
even iwas trying to figure out how you went so far till i saw the vent mod..... i goa do that... i wana be in th 900 club..
im seeing the same results.. its looking like solid mid 20's...
#42
Ok folks, finally filled her up. Smarty Beta V4.2 sw#9
1302.6 kms (814.125 mi)
138.997 Litres (36.77 USgallons/30.55 impGallons)
10.67 L/100km (22.14 USmpg/26.65 impMPG). Overhead was reading 22.9 USmpg.
Not too shabby I dont think. All told over the last 4 tanks (2854 miles) I am averaging 20.4 US mpg.
