skis question, swapping 06 cummins into ford
i am going to put a 06 cummins into my 97 ford i have a complete running doner truck with 50,000 miles on it. is there any way that i can integrate the skis into my ford so i dont have to mess with sending the computer off and that kind of stuff? i am kind of scared to start pulling wires, because i dont know where they all go
if i do have to send off the computer, from what i understand they delete the vin from the computer, then can i put a chip on it? dont the chip save the vin number? the chip wont work if it doesnt have a vin? right
i want to build a engine stand and put the motor on it so i can start it and work on it on the ground before i put it in the truck. i am going to put the dodge rear end in my ford. and the tranny.
pretty sure painless makes some stuff to help people make the swaps easier.. Contact a few of the companies thAt specialize in the swaps and fire some questions at em. Good luck my buddy just put a 95 12v in his 97 f250..
This is a good website regarding swapping the Cummins (including the CR motors) into the Ford (and others). They have a specific section for the OBS Fords.
http://www.fordcummins.com/
Also check out www.destroked.com. They have most of the stuff you will need to do it.
Plan on the truck being out of use for 1-2 months,and many ,many,many man hours of thought,schematic reading,scratching head ,and redoing almost everything later in the conversion.Making the C/R run on the floor is easy I used 2x12 and made a rectangler box to set it on ,the oilpan lip and a small spacer worked great it was there 11/2 year and I would start every couple weeks,fuel was bottle feed from a washer fluid jug and a nipple /rubber washers and thank nuts. A couple of pieces of strapping material attached to the motor and box and you can pick up both together to move .
Another good reference: http://www.4btswaps.com/forum/index.php
Also, post your progress here...It's always good to see projects in process and the results!
Tony
Tony
