six-gun and bdpp?
six-gun and bdpp?
this is my first post and i hope yall can help! i have been thinking about stacking my six gun w/speed loader and a bully dog power pup? i have been reading and i think this is the only thing that might work with the banks. any one know first hand? i dont really want to ditch the banks. i also have some kind of quad box... not sure what it is... it has a three position switch and two plugs (map sensor and rail pressure i think) coming out of it. does any one know what it is? would it work in a stack better? thanks
I stacked a SMARTY with just a Banks 6 Gun (no speedloader). With SMARTY on #9 and Banks on 3 i made 412 HP, and 820 TQ. Stock trans does not like this combo though, stock trans does not like SMARTY on 7 or 9 just by itself..
Ummmm
I can't say for you man, cause everyones driving habits are different. If you are not beating the snot out of it, I would say yeah, as long as you take care of it and do not pop the clutch all the time. Also no boosted launches, no drag racin either. All i do is the occasional wide open throttle runs and I can slip my trans at will (although I think it is actually the torque converter).
If you turn smarty down to 3 or 5 and Banks to 3 or so, you should be fine, but the temptaion is great to turn up the SMARTY, and when you do it is so fun, you almost forget about the trans/clutch till you slip it.
Sebaruwrx
02-10-2007 02:10 PM
Barrett_Fodder
18
10-11-2004 01:55 AM
gdh11
03-08-2004 05:45 AM
