Sirius install using factory antenna wire?
Old 01-14-2008 | 10:59 PM
willysrule's Avatar
My truck came with Sirius but I let it expire because I have another unit that I can take from vehicle to vehicle and also use it in the garage...my question is, has anyone tried to hook up there aftermarket unit using the factory wire and antenna? I'm thinking if I can tell witch wire it is (going into the back of the head unit) I might be able to splice my antenna plug onto the factory wire...
I have successfully spliced these wires before, I ripped the wire I use in the garage and was able to splice it back together and now it works fine...
Old 01-15-2008 | 10:10 AM
kuhkuhkyle's Avatar
they say you cant splice the coax cable. but who knows. those antennas are like 50 dollars so its probably just a ploy to sell more.
Old 01-15-2008 | 10:17 AM
BlackSheep5's Avatar
the Sirius reciever is in the dash some where and the antenna plugs into it, there is a patch cable that runs from the reciever to the head unit
this is from Dodgetalk.com
"In the 2006's, and probably 2007's, the Sirius receiver is located under the dash on the RIGHT side. If you take the glove box out (just squeeze the sides together so you can open it beyond the stops and it will pop right out), then look up through the dash it is right there, mounted on a metal plate (they use some pretty serious bolts to hold that thing up there too!! ).
I just put a stereo in my 06 this weekend and replaced the sirius receiver. I took the plastic clip off the end of the antenna wire and it plugged right in."
Another guy says:
"I replaced my factory system with an aftermarket Kenwood deck. In my 06 QC 1500 the Sirius tuner was located above the glove box, below the air bag (just pull out the glove box). I was able to pull the factory sirius tuner and put a Kenwood model in its place.
You can use the factory antenna, it uses the standard (I think SLA) plug. You just have to break off the big plastic stock plug housing, and underneath is the standard plug, should go right into an aftermarket unit. However, I don't think you'll have enough cable length to get it out onto a dash-mounted aftermarket unit like a sportster."
Old 01-15-2008 | 10:50 PM
willysrule's Avatar
kuhkuhkyle:
I've ripped them many of times and spliced them back together...they work just like the coax for a TV....two "runs" in the "wire"
BlackSheep5:
AWESOME...that is what I wanted to see...Thanks a million!!!!
Old 01-16-2008 | 10:06 PM
willysrule's Avatar
for anyone else doing this....
I fould the shortest extension cable you can buy....
http://www.myradiostore.com/sirius/s...ension-xm.html
Old 01-17-2008 | 04:40 PM
BigHornCTD's Avatar
I think I will go this route as well...Thanks for the link!
Old 01-17-2008 | 11:27 PM
willysrule's Avatar
did it today....works great!!! that was ALOT nicer than running a whole new wire...
Old 01-18-2008 | 10:07 AM
does XM and Surius use the same antenna?
Old 01-18-2008 | 11:55 AM
willysrule's Avatar
I'm not sure of that, but the extension that I bought from the link above will work with XM or Sirius...so maybe they are the same...
Old 01-18-2008 | 12:06 PM
BigHornCTD's Avatar
I can't vouch for all the models, but my XM Roady 2 uses the same antenna. The extension cable that Willysrule posted is listed for both.
Old 01-26-2015 | 12:34 PM
DECEPTiON21's Avatar
I can confirm this, years later. I put an pioneer avh-x8500bhs with the sirius tuner. It came with an antenna that i ran for about a year. I finally decided to try and use the stock antenna. It was way easier, I'm mad i didnt do it sooner.
kerry.king
04-05-2012 09:32 AM
plug ugly
01-04-2011 05:18 PM
Utundra
12-24-2007 03:38 PM
caseyclan
11-03-2006 11:06 PM
twhman
07-11-2006 01:17 AM
