Single vs. twins Question
I have a SPS62, DDP 90's TNT/R and make 605hp with EGT's NEVER getting over 1400*.
Dont let others tell you that the SPS62 cant handle power without heat. While running a Smarty my temps have NEVER been out of control.
My WG is currently set at 50 psi and I run 1:1 until 45 psi then at max boost I see 1.1:1, which is perfect.
It does spool a little slower than stock, but once you hit 10psi, it lights like no other. Twins are nice, but for the money the SPS62 is a much better option IMO.
If you decide that you want twins down the road, the SPS62 will make a great top turbo with a S480 under it.
I am very much a cheerleader for my SPS62, it has NEVER disappointed me in any way. I run it hard all the time, take it to the track, and numerous dyno runs, and it performs PERFECTLY every time, very predictable and efficient.
As far as weight is concerned, you right I dont have 10,000lbs to put behind my rig...but the 6K that I do tow, tows very well. As long as I stay on top of the lugging I can run 70mph up Donner Pass all day long and stay WELL below 1200*.
dodgediesel
17
04-05-2011 11:21 AM
hotrod929
01-27-2009 04:53 PM
Stock 02
28
09-24-2006 11:09 AM
