Single DIN radio adapter for Nav truck?
I got a single DIN radio adapter. This is the one that has the small cubby hole under the radio.
I would like to get a Navigation Bezel and a single DIN radio that would have a much biger cubby hole. The reason is I would like to mount my brakesmart controller there. I mounted it on the knee bolster and it looks out of place.
I checked Circuit City, and they have no such beast. Does one exist yet? I imagine there are not too many ppl with Navigation looking to go single DIN..
Well I work for Circuit City. We dont have a dash kit yet and for one reason.. No one has developed a box yet that allows an aftermarket radio to interface with your trucks CanBus System. All it is really is that your radio puts out one volume level to and amplifier when you turn the volume up it sends a signal (data) via one wire to the amplifier (located above your glovebox) telling it to turn up the volume. Other than that I am not sure if you could just bypass the whole deal. I have put amps in and even 4 speakers and another 4 channel amp after the factory one all on a factory stereo. But we are not allowed as of yet to replace that stereo due to this Data system that I GUESS may be tied into other functions of the vehicle like GM's.
Actually Peripheral makes an interface piece for the CAN bus system which I have already used in a vehicle. I beleive the part # was CHYAH05, worked great, also had input to turn on facotry amp, output for park brake, VSS, reverse wire. Really sweet little piece when trying to add an aftermarket NAV.
Well thats news to me. We still dont have the adapter yet. I look forward to it seeing a lot of people are waiting. We sell periphrial, usaspec, metra, AMI, and I can order PAC stuff but the last we called they said it wasnt available and would be for a while, I will check tommorrow on those part numbers.
Yep they make one
http://peripheralelectronics.com/web/onstar.asp
then add this kit
http://www.installer-data.com/item/d...php?it=99-6510
with the factory nav dash trim
then add this kit
the doge nav bezel is part # 5JZ131Z2AC looks like it is about $57
just toss that number in this webpage
https://www.dodgeparts.com/oe_parts_...49ffedcb5b47a4
Purplezr2
04-23-2012 03:46 PM
jp127761
03-03-2011 04:07 PM
JWillms81
28
05-28-2008 11:08 PM
PASSMORE
09-07-2006 09:49 AM
Guy L
12-22-2003 08:25 PM
