Simple fuel pressure gauge installation questions
Old 12-22-2005 | 08:02 PM
dgibbs's Avatar
I bought a Plews 18" grease hose to connect between the fuel filter cannister and the fuel pressure isolater. The hose is rated at 3000 P.S.I. so I assume this will be ok to use? They had a heavy duty hose rated at 4500 P.S.I. but it was only 12" long and I wanted the extra length. (who doesn't want a couple of extra inches... ) I digress......
Also, should I apply any type of thread sealer to the banjo bolt or grease hose fittings?
Old 12-22-2005 | 08:14 PM
P.J's Avatar
P.J
The banjo should have a factory washer with rubber coating on it.
I used liquid teflon, people recommend against using regular teflon tape.
I think the 3000 psi hose should be fine, only overkill by about 2980 psi.
Old 12-22-2005 | 09:01 PM
dgibbs's Avatar
Thanks P.J. I figured I was ok but just wanted to double-check.
Old 12-22-2005 | 10:19 PM
dgibbs's Avatar
Thought I had everything but just noticed that I am missing a fitting. My grease gun hose has two male ends but the pressure sender is a male end also. Look's like I need a connection with two female ends with 1/8" NPT threads. Is brass what I should use?
Townsend600
06-25-2007 11:35 AM
Casey Balvert
06-07-2007 12:11 AM
MoparRiggan
01-05-2006 12:09 PM
1qckdodge
07-17-2005 01:34 AM
engcogod
17
02-03-2005 09:49 PM
Quick Reply: Simple fuel pressure gauge installation questions
