Silverstars, Brite Box, and Fogzilla Mod Installed (pics)
I just got done installing the Brite Box (SD8+FLC), Fogzilla, and Silverstar Ultras in all four lights and I just wanted to say the combination of these two things = VERY BRIGHT LIGHTING OUTPUT!
I can see twice as good now going down the road which in turn is safer for me and brighter is always better. I highly recommend this easy mod to anyone. Here are a couple pics; sorry their crappy. It's starting to spit a little rain here and the camera wouldn't focus right.
Everything should work just the same on an 07.5. Just make sure you get the 06-07 kit. The Brite Box is a relay based module that plugs into your factory headlight harness and keeps the low beams on when you flip to the high beams. The "FLC" (Fog Light Control) is an option that also lets you keep your fogs on in conjunction with the high beams and low beams. The Fogzilla mod is a harness that converts a 9006 bulb into a 9005 high beam bulb. It gives nearly twice the light. Finally I put Sylvania Silverstar bulbs in all 4 lights. They aren't the best, but a huge upgrade over stock. You can get the Silverstars at any parts store (AutoZone, Oreilly's, Advance Auto Parts, Napa, etc.) and the other stuff can be purchased online. I got mine through Geno's Garage.
I THINK I'm gonna do the Low w/ High wire mod I wrote down from another thread. And maybe Silver Stars, though I don't really dislike whatever is in my '03 right now.
I know low w/ high will be great, because I go down the darkest part of the road home with the high beam flash lever pulled back a bit and it keeps the lows on too.
DodgeCowboy
12-26-2012 12:50 PM
400Magnum
17
12-16-2009 09:55 AM
Igor
04-25-2006 03:27 AM
Igor
04-20-2006 01:48 PM
Hondo
03-21-2005 08:04 AM
