Short Shift Kit
Old 09-20-2004 | 07:42 PM
HighTen's Avatar
Short Shift Kit
I am wondering about a short shift kit for the 6spd. I know about the BD kit but are there any others? I need to go fast sometimes... but it seems like it would be good for towing when you want to shift fast and keep your speed up. Thanks for any info.
Old 09-20-2004 | 07:57 PM
Mexstan's Avatar
The short shift kit does NOT make your shifts any faster, only shorter.
Old 09-20-2004 | 08:05 PM
cquestad's Avatar
True...but if your shift happens to be limited by a slow hand, then a shorter shift distance could yield a quicker shift.
Old 09-21-2004 | 06:25 AM
sherman's Avatar
shift
As said before the shift is shorter not guicker,you still have to wait for the engine unless you want to slip the clutch.
Old 09-21-2004 | 09:56 AM
cquestad's Avatar
Isn't a clutch made for slipping?
Old 09-21-2004 | 10:05 AM
HighTen's Avatar
Ok, I feel better now. I was thinking that too.
Thanks for the cautions. I know there's no gaurantee of a faster shift and the driver is still the one who really desides the speed. Does anyone have some personal experience with one of these kits?
Old 09-21-2004 | 07:21 PM
spinlocker's Avatar
I have the BD kit on my 6spd 03. Although a bit expensive, I found it worth it. If you purchase, be sure you have a 10mm 4" extension to remove the shifter console, and I'd recommend some of that hi temp copper silicone stuff to seal up the short shifter tower. Give it about an hour to install.
Old 09-21-2004 | 07:28 PM
Mexstan's Avatar
I installed mine shortly after I bought the truck. The instructions leave a little to be desired but if you have any mechanical know-how, it is not too bad to install.
It is extremely important that you clean all faying surfaces very well and then apply a good quality gasket maker or I guarantee it will leak.
It works OK and I have had no problems with it. I keep my elbow on the center consul and then using my wrist only, go thru all the gears.
Old 09-22-2004 | 09:58 AM
HighTen's Avatar
Thanks for all the help! I feel good about my mechancal skills and the getting through the installation so I may go for one...but we'll see what we see.
Old 09-22-2004 | 10:09 AM
BigBlue's Avatar
I know it ain't the same, but we put one in the vette and it made a world of difference. Before we were blowing synchros left and right (so much for internal stops). Afterwards, haven't had a problem. I've heard of some people complaining of notchiness with the BD shifter. Don't know much about it but thought I'd give ya a heads up.
rich2500
07-30-2005 08:33 AM
EKUgrad
04-23-2005 07:55 PM
caltom
03-28-2005 08:42 PM
cummins dsl
13
02-14-2005 08:20 AM
yannick
01-31-2005 08:51 AM
Quick Reply: Short Shift Kit
