Shock bushings?
Shock bushings?
I think my bushings in my right front Bilstein shock is going bad. It keeps making a heck of a clunk when I hit any kind of bump. Does anyone know of where I can get replacements? This is the second to go bad, first one was the left front. Any other replacement shocks hold up better?..
i just changed my old bilsteins yesterday ( they had 50,000 miles on them) bushings were in good shape.i put another set of bilsteins on the truck.. since the noise happens when you hit a bump- it could also be other things- start with the shocks. check your trac bar (make sure it is tight-no movement) you may want to jack the truck up and check the tie rods and ball joints too. move tire up and down-any movement other than a tiny bit-bad ball joint. move tire side to side- any movement- bad tie rod. could also be a bad anxle u-joint. unfortunately with that type of noise/symptom (many guys have had it) it becomes a process of elimination. take your time and go over your front end.
Which Bilsteins do you have? 5100's or the HD's (Yellow and Blue). I just put on my 5100's yesterday and they say the front's are good for 0-2.5" of lift. My truck is at stock ride height and the fronts are compressed alot more than I think they should be. Wonder if yours are the same and that has something to do with pre mature bushing wear.
freight train
22
03-25-2013 04:46 PM
stumpjumper
08-21-2007 07:14 AM
