seems like truck is running out of fuel at 70 and above?
ok guys when im getting on my truck on the interstate it seems to hesitate a little bit and stumbles it really seems like i am running out of fuel. i have a fuel boss lift pump and the smarty turned on sw9 rp2 tm3 timing 1 wastegate off built trans with tripple disk when im cruising and put it down at about 70 it will not necessarily stumble but it just seems like it isnt pulling as hard. the rpms are about 2000 and from there up it just seems like the power isnt all there is this because im past the power band? im gonna adjust the smarty down to sw8 and see if maybe im getting tomuch timing and then to 7 and go from there any suggestions would be great thanks oh i have 3.73 gears as well
jsflagstad
06-10-2007 06:43 AM
