Saftey Measures
Saftey Measures & Boxes
Which box has the most saftey measures the Edge juice w/ Att or the Bully Dog tripple dog w/ outlook? Also, has anyboy stacked these two boxes with a stock fuel pump? Last of all, is it worth the $$$ to get the Xzillaraider XZT and use it with the Juice or is it more worth wile to save up for the TST?
I recommend running an aftermarket Lifter Pump (FASS, AIR DOGG) I was using a Quad standard and it seems that the stock Injector pump couldnt take the 100hp. I had to put the truck back to stock and leave it at the dealership for about a week. They covered it although they had suspisions. Good luck with whatever you choose. Ill be getting another box once i get a pump in there.
Sorry I'm going to build my trans to suit!! I cannot see wasting money on a box that defuels at the slightest hint of being overpowered!!!
I may spend extra but it will be right the first time guaranteed!!
Rick
Rick
Rick
Rick
if your worried about money, then keep your truck stock. Having what you are looking for is going to cost $$$ and lots of it. The transmission itself is 3k+ and thats not including the turbo upgrade you need plus the box, and all the other stuff just to use the power!
What I am doing is slowly getting to that point. I only have the edge juice. because i know my truck wont be able to handle much more. Then when I upgrade my tranny and turbo, then I will sell the edge and get my TST stack. If you want to do it all at once, then do a search and do it right the first time. But if you dont have the ability to do it all at once, then work yourway up!
