S400 or S480?
Old 06-30-2008 | 07:20 PM
homewrecker's Avatar
S400 or S480?
Getting ready to drop the wad on the twins.Just wondering what the spool difference is going to be between the 2. I still tow with the truck and would like something "relatively" quick spooling.I have even considered going to a 65 wheel on my 62/13ss to help with spool up.Lets hear the opinions.
Old 06-30-2008 | 07:50 PM
soulezoo's Avatar
DTR 1st Sergeant
In my opinion, any time you depend on towing, you are going to want better spool starting at a lower RPM... How that does it is dependent on your secondary. Top HP support is going to depend mostly on what you have on the bottom. Keeping in mind the secondary still has to process what exhaust is coming out and what the primary is feeding it. That said, the turbo you have now can be expected to spool slightly slower in a twins set up. Can you live with that? If the answer is no then go to the 65 wheel. If the answer is yes, then goto the next question... ultimately how much HP do you want to support? In either trim, your secondary will handle either primary choice. The 71 wheel will handle the s480 slightly better but at the expense of lag. I think that anything above 700 as a HP target go s480. 700hp and below, go s400. Just my thoughts, but this is what you should be asking Nathan... With your sticks and TNT, Mp-8... you are close to or up against that 700hp mark with twins any way you cut it.
Old 06-30-2008 | 08:11 PM
Well put soulezoo.Not looking for huge numbers.Might need to consider the 65 wheel because the spool up is already a touch slow for towing heavy.If this truck got anywhere near 700hp I would be more than happy.
Old 06-30-2008 | 08:26 PM
bluechrome's Avatar
I'm going with a 62/71/13ss over a s-480. The way I look at it is I've towed a hand full of times with a 66 and it's doable but laggy and hot. I think the twin combo I Want will be ten times better spool the Bullet. If the 65 Wheel would keep up with a 74mm s-400 on the bottom then that what I would do.
Old 06-30-2008 | 08:42 PM
Might just go with the 74 S400 and try it with the 62/71.If I'm not happy with spool up I can send it off and get it changed.At least it will be easy to get at to get it off!
Old 06-30-2008 | 09:00 PM
soulezoo's Avatar
DTR 1st Sergeant
With your setup, you want the s480... you will be well into 700's and into the 12's in the 1/4.
Old 06-30-2008 | 09:02 PM
bluechrome's Avatar
Ya if the tranny could handle it, but yes s-480 it will be
Old 06-30-2008 | 09:15 PM
Sloverado's Avatar
I like the S480 as well. With a 66 it not laggy at all but I have alot of fuel. I would not be afraid to have a 62/71/13 as a top and still pull heavy.
Old 06-30-2008 | 09:56 PM
Rpainter's Avatar
wher is the best place to get a s480 turbo without killing the bank? I am wanting to runs twins with my silver bullet as a top charger. just trying to get a feel on price. sorry to hijack
Old 06-30-2008 | 10:15 PM
wap's Avatar
wap
A S474 is gona be a bit cheaper than the 480, so IMO you should get the 474 and see how you like it and if its not enough upgrade to the 480.
Judgeing by your posts, I think spool up is top priority and top end hp is secondary. I may be wrong but I think you would like the 74, again, just judging from some of your posts.
Old 07-01-2008 | 02:29 AM
desertchecker's Avatar
IMO go for the s400 non - wastegated & keep your 62-71-13ss for the top turbo !
that setup should be a bit easier on transmissions & will be much better suited for your needs ! vs the higher hp potential & unreal top end of the S480-62-71-13ss combo
Old 07-01-2008 | 02:36 AM
kanuckle head's Avatar
How about a fast spooling Garrett BB lota choices
Old 07-01-2008 | 06:16 AM
Had considered a GT42 but its alot more moolla!I'll talk to Nathan before the weeks up and see what he thinks.I'm just tired of changing thing 2 and 3 times before I'm happy with it.Really want to get this right the 1st time.
Old 07-01-2008 | 11:42 AM
01smoker's Avatar
Has anybody a twin setup using thier stock turbo and a silver bullet? I was wondering about this since I have both and just need the plumbing and exhaust manifold.
Old 07-01-2008 | 11:48 AM
soulezoo's Avatar
DTR 1st Sergeant
Then he'd be changing the top turbo because the GT42 will lite quicker than his top turbo...
Trust me on that one... I know...
Sixpack73
15
07-17-2009 08:31 PM
jvjump
26
07-16-2008 12:03 AM
homewrecker
07-11-2008 03:54 PM
mykal41
23
06-06-2008 01:42 AM
nrussell
22
04-23-2008 03:50 PM
