S&B intake.. Is the "filter" any good. Looks like a K&N! [YUK]
Old 07-26-2007 | 12:30 PM
THURENfab.'s Avatar
Just curious if the media is any better than a k&n.. I don't feel like sucking dirt into my engine, like I've seen a million times with a K&N, but I don't want to toss it if it's any good..
Thank you!
Old 07-26-2007 | 01:32 PM
Hunter11's Avatar
I have had my S&B for 1 year and have never had any dirt get past the filter.
Old 07-26-2007 | 01:51 PM
TX_Diesel's Avatar
I've had bad luck with K&N's on diesel motors.
I think the AFE dry or any of the newer dry type filters are better than the oil type.
IMO
Old 07-26-2007 | 01:59 PM
cquestad's Avatar
I think your fine...Don.
Give er' a test run in the desert and see...
Wipe a little greese on the inside of the intake tube to see...at the 90.
Old 07-26-2007 | 04:28 PM
Pooter's Avatar
Just pick up a Amsoil 4090, and a prefilter
For me the oiled filters get dirty almost immediatly after I clean them, so far my amsoil ive had on for about a month still looks brand new, I checked the intake tube, NO dust/dirt.
I think ill get a prefilter too, to keep more of the larger dirt from getting to it, easier to clean the perfilter more often, and keep the filter cleaner...
Old 07-26-2007 | 09:42 PM
THURENfab.'s Avatar
Thanks all!
I think I'll do the "grease in the boot test" and see if I get any dust.. When I hold it up to the sun I think I see less light than a K&N which would be good.
Pre filter sock wouldn't hurn either, but once I'm done with my chopped fender inlet, I won't get big chunks in there anyway..
Old 07-26-2007 | 10:26 PM
fordracing19's Avatar
Mine still looks clean after 8k miles.
Old 07-26-2007 | 11:57 PM
triplenickel's Avatar
I've had mine for a couple years and never had any dust get past, they are an 8 layer not 4 like the K&N.
Old 07-27-2007 | 10:31 AM
cquestad's Avatar
Chopped Fender Inlet? Hmmmmmm?
Get back on those bumpstops!
Old 07-27-2007 | 12:54 PM
THURENfab.'s Avatar
Bumpstops blahhHHH!!!
I'll post picture of my intake.. It's being a "female dog", but should be pretty cool when done..
So I did some looking at the ISO 5011 test and it is NO JOKE! Here's a link I found that did an independent(hmmm, I never buy it, and it seems like AC delco funded this test) test on some different brands for the Dmax..
ISO 5011 test
No S&B in there, but it just gives you an idea of how different brands perform. Kinda surprised at the Amsoil specs..
The S&B is sounding good if it lives up to the specs claimed from them..
Old 07-27-2007 | 03:33 PM
cquestad's Avatar
If you rule out K&N...there is a 1% spread across the board...
I would never bank on...or worry about...or ever be able to duplicate 1% in the real world.
Go with personal experience...
Oiled foam is hard to beat...
I would like to find a 13-14" long 8" base...4-5" tip with a 6" inlet...UNI.
Till then...I guess I will run my 5 Layer AFE and pray.
Old 07-27-2007 | 03:45 PM
staarma's Avatar
I never have had any dust with either the standard or PG7 AFE 6" X 9" so you should be ok. I haven't tried the dry flow AFE though.
Old 07-27-2007 | 05:53 PM
53 willys's Avatar
I cant find the Amsoil part number they show ts123?????
is it even the nano fiber filter that they tested???
the report says 2004...was the amsoil nano out in 04?? I cant remember it would be close to the time the nano came out????
Old 07-27-2007 | 05:55 PM
cquestad's Avatar
Nahh...its an OLD test. It is the oiled gauze or foam one they had prior.
Dodgezilla
11-30-2008 07:29 AM
sheriffav8r
05-29-2008 07:47 PM
farmer0_1
08-09-2007 12:58 AM
tacook
10-31-2006 12:17 AM
