Running 1 psi on the freeway with bigger turbo
Old 11-25-2007, 09:18 AM
barryp's Avatar
I put a 64/14-71 on my 2006 last week. I used to run 5-6 psi on the freeway at 70mph, now I am running 1-2 psi with the larger turbo. Have others gotten the same results? Is your fuel mileage suffering from this? It seems to run good and spool up quickly, just wondering how this affects everything. Thanks
Old 11-25-2007, 09:42 AM
jrussell's Avatar
It's common to see reduced boost while cruising with a bigger turbo, but that sounds a little too low. Is there any haze while you're cruising? Have you done a thorough leak check on the manifold at the head and turbo flange?
What's your max boost look like?
Old 11-25-2007, 09:47 AM
tritont's Avatar
that sounds normal to me too as that's what my 64 did. At 70 running with low rpm's the drive pressure is very low so you're not going to be building a lot of boost.
The joys of owning a larger turbo :-)
Old 11-25-2007, 09:53 AM
tcr
tcr's Avatar
I'll see 2psi or so at 70mph w/ a 62/14.
Old 11-25-2007, 10:14 AM
Luvnacumns's Avatar
Originally Posted by tritont
that sounds normal to me too as that's what my 64 did too. At 70 running with low rpm's the drive pressure is very low so you're not going to be building a lot of boost.
The joy of owner a larger turbo :-)
Yepper... With my 5k turbo that's what i would run too!!
Old 11-25-2007, 10:25 AM
jwb600's Avatar
I drive around and the boost gauge barely moves lol. in town its like the boost gauge doesnt work. but when it needs to do its job it does
Old 11-25-2007, 10:52 AM
RamWheelsBy4's Avatar
I see around 4 psi at 75+mph crusing with my SPS66. I does depend on how sensitive your gauge is on the low and high end. My autometer gauge does not really start moving accurately until I see around 4psi on the TST Remote.
Old 11-25-2007, 12:00 PM
OldSmokey's Avatar
Mine is about 4 psi at 75.
Old 11-25-2007, 12:27 PM
Little03's Avatar
My 66 is 4 psi at 120 kmh, my fuel milage is still decent.
Nick.
Old 11-25-2007, 12:32 PM
Sailpipes's Avatar
The new turbo is moving the air more efficiently. The pressure is down, but it's moving just as much if not more air that the stock turbo was.
Old 11-25-2007, 02:27 PM
cgmorgan06's Avatar
Will going to a bigger turbo hurt fuel mileage, or will it not affect it at all?
Old 11-25-2007, 09:04 PM
Woodchuck61's Avatar
I noticed a drop of 1-2 mpg with the 62-14 but performance improved so much I wouldn't go back.
Old 11-25-2007, 11:43 PM
sid325's Avatar
I see about 7psi at 80mph with my HTT 62/13.
Old 11-26-2007, 02:27 AM
HOHN's Avatar
Not a chance. When A turbo is operating at 30-40 psi, a bigger compressor might move more air (mass) at lower pressure, but when they're both on the bottom end of the map (or not even on it), pressure is pressure, and 6psi is more air than 4psi.
It's part of life with a bigger turbo-- lower cruising boost means higher average EGTs.
jh
Old 11-26-2007, 09:00 AM
OldSmokey's Avatar
I just got back from a 400 mile trip last night. TST 1, X2 milage max, at 65-70 I got 20.4 mpg. 75-80 was about 18.2. This is with a new 66 with only 100 miles on it when I started! On mine the bigger turbo didnt hurt my milage. My exhaust temps for most of the way were around 600-650 and boost was 2-5 psi.
Quick Reply: Running 1 psi on the freeway with bigger turbo
