RP Qustions??????????
Old 12-13-2008, 04:38 PM
2007 5.9's Avatar
See that s the question....with stock programming my cruising RP@65mph is 17K, and when using RP-3 its the same.
The only thing I see with the Smarty is when I depress the throttle from 65mph, my RP goes up to 20K and hangs out there until I back off then it settles back down to 17-17.5K
Then with anything over 1/2 throttle, it jumps to 24.5-25K, where as with stock programming it wont hit 25K until full throttle and at high RPM's.
Is it the occasional jump to 20K that kills them or the sustained 17K that I see while cruising????
Old 12-13-2008, 04:40 PM
dieselram_04's Avatar
I suppose if it was a very violent jump to 20 it could possibly crack a injector for the most part i think 24k is the norm for the 04.5 trucks mine maxes out at 22 but i have stock pump and 80hp injectors
Old 12-14-2008, 07:40 AM
MikeyB's Avatar
Originally Posted by rip 112
At wot it will hit 23k and flash 24k a couple of times, but I haven't seen it pass that by much with it on 100% either, 24.5k or so. Crusing its hit and miss, I don't like to exceed 17-18k at any time cruising unless I'm hittting a steep incline.
Thanks Rick.
It's something that I won't be running daily but only as a power booster for when it's needed.
MikeyB
Old 12-15-2008, 11:44 AM
rodriguez7's Avatar
With my smarty on rail pressure 2 and the mp-8 at around 50 percent, at 75 mph on the freeway im right around 16 or 17 k, I try to keep it around 15 or 16, if i hammer it to pass i can hit around 20 to 22, higher if i crank the mp-8. I have around 97 k miles on my truck, been running some kind of pressure on the stock injectors for around 75 k. Been good so far, knock on wood.
Old 12-15-2008, 03:33 PM
rip 112's Avatar
Oh yea you'll be fine, I'm just over 100k and the trucks running better all the time...
walks
01-23-2012 05:26 PM
BC847
07-04-2010 03:46 PM
sleeperman
11-17-2009 12:40 PM
GaCamper
02-08-2009 11:11 PM
DISTURBED
08-20-2006 11:46 AM
Quick Reply: RP Qustions??????????
