Rokk sensor installed!
This morning I installed my Rokktech sensor, question is they say insert the sensor in the hole and tighten til snug, ok then they say turn the sensor clockwise until it stops, is it just me or does the sensor only turn a very small amount hardly at all, before it stops, but I turned it all the way until it stopped so I guess it is at full advance, right? I did not notice any difference in engine noise, I thought the engine would be a little louder? I did notice some low end grunt!
I think what the guys meant when they made that instruction setup was to have the bolt in the treads, and then turn the sensor to the clockwise position, then tighten the bolt down. I have noticed a difference in the power as well, but like you said, I haven't heard the noises at idle.
Just to make sure I am hearing the engine correctly; when the engine makes a knocking noise like the instruction manual states from Rokk, is it loud? I am just a little worried that I am not hearing the noise I need to hear. Any input would help this newbe (me) and the others out there. Thanks guys...
Jake
Jake
The Rokktech doesn't move much to get the 2 degrees of timing.
I didn't see a change in max boost, but I have a 555. The 600's may be a little different.
MikeyB
MikeyB
AlCorr
14
01-22-2007 05:35 AM
Hairtrigger
08-25-2006 06:15 AM
Nav
07-25-2006 11:34 PM
vernl
04-02-2006 11:00 AM
Xonid
01-23-2006 08:17 AM
