rocktec timing sensor(how to set)???
i just bought a used rocktec timing sensor and it came with no instructions. can anyone help with best setting for most mpg???
Had mine set full advance 2 degrees I believe. Put in place of the stock one and rotate as far as it will go toward front of truck. Not sure how much timing the quad module adds. May be too much with the rokktech. Someone here has probably tried it and will chime in. Took mine off when I got the Smarty Jr.
I would install it as was suggested, at full advance, and see if you get any timing rattle. If you do get some rattle then start backing it off a little at a time until it's gone. Do this after the truck is warmed up...
buzzinhalfdoz
04-06-2009 09:00 AM
