REVO setting ?s
REVO setting ?s
Are Stock settings Smarty stock or Cummins stock?
Anybody use the Fuel economy setting on the Timing setting and what are the results?
What are you all finding to be the best for fuel economy?
SMARTY stock is the latest Chrysler program for that download.
Every truck seems to be different so experiment and find what works best for your vehicle. Since you have a stock tranny I would start with level 3, TM2, Timing 4 and try Rail Pressure 1 with the Wastegate disabled.
MikeyB
MikeyB
When I got my Smarty, I put #3 in first and within 10 minutes my clutch was slipping (doh). $1800 and a new clutch later (Con-OFE), it's great... I have the timing set to 4 (economy) and I'm up about 3 mpg. I'm going to try setting #5 soon.
I haven't tried disabling the wastegate, so I only get 30 psi... what would I get if I disable it? I know the turbo (HY35?) is only good to something like 35-40 before you risk damaging it... or rather, that's what I've read here on DTR.
Rob
Rob
Smarty question, whats the difference between the smarty 4.11 atermarket turbo stock injector sw and the current TNT? I am running sw 5, TQ4, RP1, T1 and It seems the 4.11 is stronger. I will try sw7 and sw 9 but I hope I don't starve the rail. Guess I need to play with it more. What are the HP ratings for each level, I know 230 is sw 9 so what is sw 5?
That truck has a stage 2 floorit cp3. Not sure how that compares to your Arson.
rallydriver
11-01-2008 12:41 PM
jmccart
06-23-2008 11:11 AM
bigwheels94
06-04-2008 09:47 AM
zack birge
05-11-2008 09:57 PM
