? on rev per mile
? on rev per mile
Hey all , I did search and found the formula for fig. the rpm but nowhere did I see if you go by the man. spec. for specific tire or actual meas. of tire and if you go by actual measurement is it the mounted meas. , unmounted , on truck , and if on truck front or rear , maybe too much thinking as I know it will also change with wear so when you come up with a fig. do you alter for assumtion of wear ? by the way new tire is Pro Comp Xtreme all terrain 305/65/17's and they look sweet on Pro Comp 1059's. Thanks..
Thanks guys , So being that this is a 33/12.50/17 we are just using a general 33 inch measurement by those calculations ? but all 33's arent truly 33 inches ? so then are we just looking for a middle ground.
look here is a easy way measure from the ground to the center of the rim
we will say that number = 15'' for grins then it goes like this
15x2= 30 x 3.1416= 94.25"
this is the inches the truck moves in one rev.
now convert to feet by dividing by 12
94.25"/12= 7.85 feet
divide that number into 5280 (thats the feet in 1 mile)
5280/7.85= 672 revs per mile
just use your measurment and this formula and your set...
also it more accurate if you do this on your factory tires and then divide your new big tire revs into your factory tire revs this will give you the % your speedo will be off
peace
peace
If you want a pretty good way of checking, go to http://www.4lo.com and click on the speedometer link on the left of the page. It will take you to a page where you plug in your original tire size, new tire size, and the speed you want converted. It will give you a pretty accurate speed based on the new tire size.
Great_big_juan
10-01-2007 01:01 PM
vansmack
05-09-2006 09:07 AM
Goggleyed
02-02-2005 09:08 AM
