Removed Smarty jr and high idle still enabled?
I removed my Smarty jr yesterday to take it to the dealer on Tues and this morning when I fired the truck up and hit the cruise button the set the high idle (did not think it would work) it idled up. Does the Smarty leave the high idle feature enabled or is something wrong? When I downloaded the stock program all went as it should, need I be worried about bringing it to the dealer?
-Seeder
-Seeder
is that high idle on the 04 305/555 in your sig?does yours work with the cruise buttons?ive been trying forever to get it to work,i took it to the dealer and everything,no luck,i also got the wire from cummins and gounded it,still no go,i guess i need the stick on the seat thingy
Smarty stock programs include all the latest Chrysler software updates... therefore, high idle is retained when loading the stock program.
Remember, when you "go back to stock", you're not loading the old stock program that was in your ECM...
High idle will work on a straight drive if you buy the pigtail from cummins and ground out pin 22 on the ecm.(I think its pin 22, do a search for the pigtail # and which pin and connector)
Spooler
21
12-26-2007 09:38 PM
ajpulley
33
03-13-2006 09:30 AM
JJP2
12-23-2005 02:29 PM
adamkn
14
04-28-2005 07:27 PM
CTDHokie
05-25-2004 10:53 AM
