recommend an exhaust brake for my application....
Old 01-17-2009 | 04:51 PM
darrenb's Avatar
with all the things i want to do to my truck, i EVENTUALLY want to upgrade to twins..(who doesn't??)
currently my truck is exactly as my sig indicates. i am getting a new dd clutch this month and hopefully a new exhaust brake.
for the exhaust brake i as leaning towards the new pacbrake or bd units. as for the twins, i do not even know where i want to begin with them as they are still a far ways out....
would my choice of exhaust brake limit the choices i will have when it comes to picking a twin setup?
i don't know much about either of this stuff, but i don't want to pick an exhaust brake only to find out it will get in the way of installing twins. i heard bd may be the only option as they have a different mounting location????? i dunno.......
i would like to someday end up with 700 streetable hp, and i would like everything i purchase to be able to work with whatever i have already done to the truck. so i don't have to spend money over again trying to fix the msitakes.
darren
Old 01-17-2009 | 05:29 PM
DODGER BOMBER's Avatar
id get an iline 5" or a inline 4" brake. I have a BD turbo mount but once i upgrade to twins, ill have to buy a new brake as i cant use mine again since its a turbo mount. But i like my BD brake alot. Its not working right now since i think i washed and blew the fuse but not 100% yet
Old 01-17-2009 | 06:04 PM
darrenb's Avatar
that's what i don't want to run into. buying something that won't work for me later down the road.
so are you saying i can use any brake i want as long as i use a non-turbo mount?
darren
Old 01-17-2009 | 10:36 PM
Ya. It depends on what twins you go with in the end, but id just buy a 5" inline and upgrade your exhaust. at least then you wont have to worry if ever upgrade to twins or large single or what ever suits ur needs.
Old 01-18-2009 | 12:24 AM
TBittner's Avatar
PAC Inline is the only one that will work with twins from what i have found. I have the factory mopar and wish i had the inline so i could do twins
Old 01-18-2009 | 01:02 AM
CD in NM's Avatar
I have the PacBrake, excellent product. It was easy to install, good instructions, works flawlessly every time.
If I was thinking twins down the road I would get the in-line model. Probably the only question between the 4" or the 5" would be related to whether you plan on going larger than the 4" stock exhaust in your down-line plans. From all that I have read regarding brake use with twins, the PacBrake seems to be the better choice. Also from all that I have read, going larger than the 4" stock diameter really benefits nothing, no signifigant gains, better to go to 4" duals for a better, smoother outflow.
CD
Old 01-18-2009 | 02:14 AM
darrenb's Avatar
CD
CD in NM,
you say you did the install yourself? how long did that take? fairly easy or kinda hard?? thanks for teh info...
darren
Rattletrap1
05-13-2014 09:47 AM
Kubotabaron
12-10-2013 03:57 PM
AK RAM
29
03-11-2004 10:15 AM
Suburbanite
11-04-2003 05:08 PM
4xWriter
08-25-2003 01:27 AM
