Recent Dyno Runs, TNT-R, BD Race Twins and Defueling, HELP
Old 08-21-2008, 05:25 AM
doug60's Avatar
overboost code
Originally Posted by mulisha
i ran into a guy yesterday at the track and the exact same thing was happening to him, but on the track. he had nathan's twins , inj,and the smarty tntR. his truck was defueling also. he's on DTR so maybe he will chime in
That would be me.
Scott @ Mass suggested I try waistgate fooler. Hes going to send me one. I have my waistgate accuator zipped tied to the frame , & a DR Perf 2021 box, when it through the overboost code.
(thanks for your help mulisha)
doug
Old 08-26-2008, 12:19 PM
highrpms's Avatar
We are stuck at the moment. MADS says they are to busy with all the requests for the 6.7 software to investigate why it is not fueling. The plan that Jason at Diesel Nut was told by BOB was that Marco would be in California in October and we were going to travel where he was. I guess that is out because, Steffano says Marco has no plans to be in California in October. I guess I am SOL.
Total bummer to take the truck to the next level to run the TNT-R only to not be able to use the power even with the mods to to accomidate it. The truck is laying down the same power as it was before the major upgrades because it is defueling.
Old 08-26-2008, 02:06 PM
bhaner's Avatar
I have/had this EXACT problem about 3 months ago and talked with Bob about it in length.
I was told it was something with my truck, and I was the only one... That he would pass the info on to Marco.
Still no fix.
I just put in bigger injectors, and bigger twins in hopes to be over 750.
I hope there is a solution to this... Your not the only one.
Old 08-26-2008, 02:15 PM
bhaner's Avatar
Still no fix.
Oh... Current Mods:
Smarty S06 with TNT-R 54
Flux 4.3's
Twin CP3's
MPI 64/13 x S480 Twins
Fass 220 GPH @ 12 PSI, 5/8 lines to both pumps
Suncoast full billet auto.
37" toyo tires
F1 H2 Cam
F1 Sportsman Springs
Banks intercooler.
Old 08-26-2008, 02:55 PM
diggity dodge's Avatar
You guys want to borrow my triple dog? Sorry I just had too. Hope you guys get it figured out becuase that looks like it should be a awesome setup.
Old 08-26-2008, 03:14 PM
cquestad's Avatar
darn 07 quirks...
That should do 850 plus...with the right tuning.
Sounds like my truck...but you need a Tst...but you can't with an 07 right?
Old 08-26-2008, 03:16 PM
bhaner's Avatar
Originally Posted by cquestad
darn 07 quirks...
My exact setup, does just under 900 on an 05...
Correct... No TST.
Doubt they are working on that either.. .
Old 08-26-2008, 03:19 PM
cquestad's Avatar
I wish i could tell you what to do....but maybe try a PMT...and if you hopefully screw up your ECM...Bob can save you with a rescue file that will maybe make that original problem go away...lol.
No...I am actually serious!
Old 08-26-2008, 03:22 PM
bhaner's Avatar
LMAO! I already tried a rescue file..
Maybe it wasn't hosed enough first though...
Old 08-26-2008, 03:26 PM
cquestad's Avatar
What does your truck do numbers wise with no electronics...say just a pressure box to boost fool? Like a MP-8 turned down? Baseline numbers...
All other parameters checked? Rail pressure in check? Lift pump pressure in check? Etc Etc...
I sometimes think the rationality comparisions the ECM does based on MAP and IAT sensors needs to be killed by Marco...a faulty sensor, wierd weather, or just bad luck can make the truck just run like crud........
Old 08-26-2008, 09:02 PM
Snapoff's Avatar
850+ is the right number with the 4.3's.
Have you taken the truck to a dealer and had them scan it?
I'm wondering if you have a sensor sending the wrong signals to the ECM?
Old 08-27-2008, 01:24 AM
bhaner's Avatar
Originally Posted by doug60
That would be me.
I have my waistgate accuator zipped tied to the frame ,doug
I have the same thing... Let me know if the fooler solves your issue.
Old 08-27-2008, 02:31 AM
highrpms's Avatar
I think we will get some answers in October. I have a boost fooler in my quad box and it did not help.
I wonder if the IAT sensor could be an issue? I wonder how sensative it is during installation if someone is taking in and out twins all the time?
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
wyocat
26
06-23-2008 01:39 PM
jmccart
06-20-2008 03:29 AM
Moobesor
05-05-2008 06:51 PM
Quick Reply: Recent Dyno Runs, TNT-R, BD Race Twins and Defueling, HELP
