Rear tire wear
Old 09-19-2011, 09:06 PM
062500's Avatar
Rear tire wear
I can't keep rear tires on my quad cab 4 X 4. They wear evenly across but the tread blocks have a slight edge. I now have a set of Michelins with a 70,000 mile tread life that are completely worn with 8500 miles on them. I am the truck's only driver so I know the tires are not abused. This is the second set. Could the stock locking rear be doing this??
Old 09-19-2011, 09:44 PM
Old Mopar Aficionado Extraordinaire
Polaraco's Avatar
When you're making turns do you hear a chatter or tires squeeling?
Old 09-19-2011, 09:52 PM
062500's Avatar
I do get an occasional chatter on soft ground or a black top road with sand.
Old 09-19-2011, 10:18 PM
Polaraco's Avatar
Have you changed the fluid in the rear yet? If not, start with that. See if the chatter goes away. Make sure you use the right stuff
Old 09-19-2011, 10:37 PM
Spooler's Avatar
Sounds like your rear axle is out of alignment. Have it checked.
Old 09-19-2011, 11:12 PM
Polaraco's Avatar
That would be a broken center bolt or a bent frame. The truck would track before it chews up tires. Not to mention handling would be in the gutter
Old 09-20-2011, 07:50 PM
Spooler's Avatar
Noop, I have seen post on here where they have rolled out of the factory with issues. We have no clutches or a locker in our AAM axles. It is a viscous type.
Old 09-20-2011, 08:13 PM
Polaraco's Avatar
MMM Yeah I know that. . . They wouldn't hold up. But it could be binding.
I never saw one out of alignment and I've had, or been around a bunch. But he did say the first set ran normal.
06 Are these 10 ply or 6 ply? It almost sounds like you have the wrong grade. You need load range E
Old 09-20-2011, 08:44 PM
062500's Avatar
The truck has been checked for broken spring center bolts, tracking, bent frame, etc. The truck is fine in those respects. I did change the fluidin the rear and used the correct MOPAR synthetic fluid. The wear is even across the tires and the tires are the proper 10ply tires. In fact the current tires whixch are wearing the worse at Michelins that were available as factory installed tires.
Old 09-20-2011, 08:46 PM
062500's Avatar
I forgot to mention that the first set of BFGs did not last much over 20,00 miles and the next set of MIchelins were no better. The current set of Michelins is the third set of tires on thetruck which only has 58,000 miles on it.
Old 09-20-2011, 08:48 PM
Polaraco's Avatar
If you haven't already, look along the rim on the tire and make sure they are E's. You never know
Old 09-20-2011, 08:50 PM
062500's Avatar
The tires are E rated, all 3 sets were.
Old 09-20-2011, 08:58 PM
Polaraco's Avatar
And the first 2 sets wore fine.
If nothing has been changed, and the previous tires wore fine. . . .
I'm looking at the tires. Not the truck at this point.
Old 09-21-2011, 07:52 AM
062500's Avatar
No, the first set was replaced at about 20,000 miles because of defective side walls but the tread was shot also. The second set were Michelins but a different model then the ones on the truck now. They did not last much more than 20,000 miles.
Old 09-21-2011, 09:08 AM
railroaderone's Avatar
could it be a heavy right foot and not realizing it. these engines make lots of torque right off the line that will chew up tires quick without slipping them
Quick Reply: Rear tire wear
