Rear Diff Lockers
There is NOTHING available for the AAM 11.5" RP
Torsen is on the Dodge
Eaton G-80 on the DMX
The Eaton unit is made of glass. Stay away from it. Torsen works quite well and I will upgrade my rear end to the Torsen unit in the future.
Originally Posted by sparky3008
I spoke with Randy't Ring and Pinion today that said my front end was a Dana 60. He gave me a Eaton part number of 19695 for a locker. When I look up that Eaton number it shows it for a Dana 44.
So is our 03 4x4 Diesel front ends a Dana 60 or 44?
Anyone know the Eaton part to go in it?
My E Locker for the my front AAM 9.25 is sitting on the floor of my buddys 4x4 shop as we speak Im putting it in next thursday,I will post all about it then and I will get the part #
I understand nothing for rear.
What do you mean when you say Torsen is on the Dodge?
Ok, I am new to this stuff so you may need to spell it out.
If the Eatons are "glass" as you say even though they really haven't been out that long I don't need something for hard core just something that works like it should in snow and slight mud in fields and such with out the 2 wheel spin.
Do you know what he would normally charge someone to install it?
Where do you Live?
I will find out Thursday when i put it in...
Where do you Live?
Where do you Live?
Originally Posted by Berak
So, can you get the electronic locker for the front end (AAM 9.25) with the 4.10 gears? I know the PowerWagon uses 4.56 gears.
1-800-298-9541
Give them a call and tell them what you have.
the e-locker is not the same as the factory electronic locker.
the e-locker is an open differential untill power is aplyed to it.
the factory unit in the powerwagons is a torsen style limited slip untill power is aplyed.
on both, once power is aplyed to them it locks both axles solidly together like a spool. this will result in binding while turning etc.
once again if you have questions, call Gus at extension 5563 at randys ring and pinion 800-347-1188. tell him i refered you and he'll get ya hooked up.
Even with the factory 4 wheel drive limited slip engaged the front wheels bind when turning. I have to either take it out of 4wheel drive to turn say into a parking space or turn like a tractor trailer. If I have the e-locker are you saying it is even worse?
I guess I was assuming the elocker was the factory unit. I'd think the factory unit would be preferred since it offers limited slip when not engaged.
Sparky, the limited turning radius is normal on all part time 4x4 vehicles that I have driven. When engaged, 4x4 mode limits turning radius somewhat, regardless of open vs. limited slip.
